I had to build a painting jig but wanted one that could take punishment by being left outside, getting full of spray filler etc.
I used scrap material and I think it took all of half an hour to make.
Two uprights on legs and the lure is suspended by springs.
Works OK.
It's fine for doing the basics and the piece being painted is stable.
To do fine detail on the top or bottom of the lure is a little more complex.
The lure needs to rotate so I welded two nuts onto the jig to allow me to slide shafts through in order to lock the lure and it works OK but there is huge room for improvement.
The second version should be ACE now that I've ironed out the bugs.
Works OK.
