Over-reving
Harry
I need some help guys. My outboard is doing something strange. I recently grease it's verticle axle. The motor is over reving when i put trottle. It still moves, but at almost idle.
I am left stumped here. Just like to have an idea before i look at the motor.
Thanks Guys.
Hey harry..i have absolutely no experience wat so ever in outboard motors but if u equate the prob 2 a cars driveline then it would a slippin or worn out clutch system..alternatively a jammed c.v.t transmission but again i dont know if an outboard has one? a c.v.t transmission is similar 2 an auto gearbox found on latest cars an smaller auto motorbikes..c.v.t=constantly variable transmission..
Brett
Harry
Did you change your plugs,if so you got the leads on wrong or maybe a dead plug.
Brett
Harry
Hi
I changed the plugs and the leads are definately the wright way bout. I haven't had time to check it out though.
salty
most proberbly its the clutch slipping. you should be getting a smell of something like rubber burning. check it out before you go into sea coz it can cause the pressure plate to crack then it wont go into gear.
Harry
Yep, the prop has a rubber bush in it which acts as a first means of protection for your shaft. The rubber had worn off causing the prop to spin freely.
All i did was replace the prop @ R480 and i was perfect.
Cheers.
Harry
Hey Salty
I love the picture with the guy fishing at what looks like a hole in the road.:D
Just the beer missing....:cool:
cpt chris
just be carful of pirate props i talk from first hand exp lost the use of two pirate props in the surf in 6 months now im back to orig not worth the risk!!
