All this talk of fibreglass and I thought a Yak was a plastic sit-on-top! Must be glass if it's being resprayed.
Anyway, for fibreglass craft....
The "seam" tape usually used is 25mm tape, available from all suppliers of fibreglass, as well as canoe, kayak and ski manufacturers. 25 mm works well as you use 25mm masking tape, the painters one, lay down the masking tape where the seam tape will go. Place a layer above and below this tape, remove the centre line of masking tape, use the wrong tape and the layer of glue stays behind on your ski, and sand the area with water paper, 220 grit will do. Mix resin and catalyst and paint on boat then apply tape dry and then wet the tape out with resin. Remove masking tape immediately. When dry sand the resin of the tape lightly, using a sanding machine and 80 grit paper. You need to get this smooth. Re-apply the masking tape above and below the seam tape and paint over with gelcoat/catalyst of your colour choice, remove masking tape straight away. A light 220 water paper sanding and polishing will give you a factory finish.
Wash brush with acetone, use disposable gloves available from Dischem. Wear long sleeve t-shirt, overalls and long pants as well as leather gloves, hat, safety goggles and a buff/scarf on the face when grinding/sanding. A hot shower with soap and a scrunchie, that orange bag thing your wife uses in the bath will remove fibreglass from your skin.
