Hi guys, need some outboard advice from the experts...
Went to St Lucia this morning for a bit of spearfishing but my outboard (yamaha 50hp 2 stroke on a C-ski 440) stalled on me twice in the mid break right after punching through about a 1.5m wave and the boat being almost vertical. It started 1st pull after each stall but after it happened the 2nd time I turned around and decided today is not my day and if it stalled in the backline which was huge I would 100% flip the boat plus the waves looked a lot bigger once we got in the water. The big commercial boats did launch although the skippers looked a bit nervous. Swell (from Richards Bay Weather buoy) was 1.8m, 10s, SE.
Anyway I have launched many times at Vidal, Sodwana, Maphelane etc. without any problems and the motor has never stalled. Usually we are fair weather divers and do not push our luck too much and I almost saw my ass this morning when I pushed a little too hard.
- As far as I could tell the motor did not submerge (would it start so easy if it did?)
- Fuel supply seemed fine and I did properly warm up the motor for almost 10min making turns waiting for a gap.
- Can/Will an outboard stall if for instance you apply a lot of throttle to punch a wave and before you can reduce the throttle the motor cavitates and maybe over revs?
- St Lucia is full of sandbanks so even when you think you are deep you might not be that deep. So will an outboard stall if you open the throttle and the prop gets pushed into the sand briefly as the bow lifts?
- Will an outboard stall from the whiplash/jerk when you go over a wave (unlikely I think as this happens often)?
Sorry if this is a bit vague but stuff happened very quickly so I am not to sure if motor submerged/prop into ground/cavitate etc. So all in all a big fail of a day but I got new respect for St Lucia and I don't have to tell anyone’s wife that her husband is in the morgue, so not to bad I suppose.
Karl
Karl
