Good day fellow member’s, I hope someone can give me some advice with a problem I’m having with the new (second hand) outboards motors I recently fitted to my duck. The detail of the boat taken off manufacturer website are as follows: Predator duck Model: 4.9M, Length 5M, Beam 2.060m, Mass 290KG, recommended HP 1x90HP or 2x40HP. When I bought the duck it had a single 85HP Yamaha year ’95 fitted to it, the motor had a hard life but was still running well, it got on a plane fairly quick and the maxed out top speed was 55KMH with a 15 pitch prop. I recently decided to get the boat ready for CAT C so the whole boat was restored and fitted two Yamaha motors 2006 40VEO with 11 3/8 12pitch props which are in pristine condition with only 80 hour on them and a full service history done by a Yamaha dealer ship. I took the boat out on Sunday for the first time with the new motors and they run very quietly and got on a plane much quicker than the old 85 but they do not rev higher than 4000RPM on WOT while the boat was carring two people and 4 x 25L cans of fuel. We played around with the tilt of the motors toe-in and toe-out and all the throttle cable are set right so the carburettor flaps open fully. I started doing some resursh on RPM’s and most of the research seems to point to the props. What I understand is for every pitch I go down I’ll increase the RPM by roughly 200RPM so from a 12 pitch down to the smallest pitch prop I can find which is a 9 Pitch I will only get the revs up by approximately 600RPM which is still far below Yamaha’s recommended RPM range for the outboard which is 5500RPM. Any suggestions on what else can I do to get my outboards RPM up would be greatly appreciated.
