ON A SALTIGA 50
mumro
howzit guys
need some help here,what do you think would be a better combination?400m 80pnd whiplash with 200m .55 giant abrasion or 400m 50pnd whiplash with 300m ,55 giant abrasion?:headb:swearREALLY MAD BECAUSE I THINK I MADE A BOO BOO!!!
Mums, ideally, you want to put 600m of 45lb Whiplash (0.1mm) as a backing. Then you can get 200-250m of .50-.55mm Mono on top. That way a spool of 600m mono will last you 3 fills instead of 2. 80lb Whiplash - is for catching gamefish!
Hey mumro..the 45lb braid will be more than sufficient for the heavys..and if u going for the heavys u need big line capacity!...so stay wiv the 45lb braid...
Jus to give you an idea off how strong your braid is u should try this...fit your saltiga onto your stiffest rod,feed line braid thru eyes and attach to a solid object like a light pole or car bumper(sometimes the wife or gf might suffice!) then tighten up drag and pulllll!!!!! You will find your drag starts to slip before your braid snaps.. Hence forth we can safely assume that the braid will be strong enough...and anyways thats why reel's have drag systems!! And anyways a big bronzie or raggie was not meant to be brought skimming the surface after hook up...lol! This breaking test can also be used to find how hard mono can be pulled before it actually snaps....
mumro
Reefman wrote:
So MUMs, did you make a boo-boo or not?
i bought 500m of 80 pnd whiplash...but couldnt fit more than 180 m of  ,55 mono.I called my tackle dealer and he told me to bring the line back[he was so cool].He then gave me 600m 50pnd,because he didnt have 45pnd:dban:eventually i fitted 600m +200m of ,55 kingfisher giant abrasion+9m of 1,2mm balzer leader:alien
NOW JUST TO GET ME A MONSTER:cel:
Blade
YOU can pull as hard as you want but the braids not going to snap master. Cut offs will occur through weakened braid, burning on bricks etc> AND fish dont pull like we would do
AD
I use (and I know many others) Kingfisher braid 600m 45lb, and top up with .55 High Abrasion. What many guys don't know with this type of tackle....even with your Saltiga fully locked on the drag...the fish if big and still 'fresh' will still pull line off your reel. (most serviced reel should never fully lock) The danger is when u start using your thumb to further break the that initial run. I rather opt for having more line on my reel than a shorter lenghth of stronger line. Also if u fish comp rules, 50lb braid is the max.
