OKUMA CONTOURA REEL
Polychaete
I wanted a reel that was smallish, light in weight, (graphite frame) had a shoulder on the spool for my thumb, at least 6:1 retrieve, casts well, all the modern gadgets like magnetic cast control, AR bearing oversize handle, and preferably not as expensive as the big brands.
My research led me to this reel, I read good reports and it complied with my requirement.   Unfortunately it was not available in S.A. at the time so I ordered it from the US and it duly arrived at my local post office two days ago.
My first reaction was that it looked very nice, but was much bigger then I had anticipated.   It is roughly equal to a “50” reel though the spool is smaller, so I decided to rather see if I can get rid of it, however the temptation was just too much to spool it with some line and go make a few casts!
http://www.sealine.co.za/view_topic.php?id=16709&forum_id=5&highlight=contura
I will “play” with the reel and write some comments and post pictures as I go along, this may be over a number of days as I try it and look inside.
Yesterday [/b]I spooled it with 275mt Sufix braid of 0.36 mm backing and about 140mt 0.55mm Sufix XL strong mono.   It was comfortably full and could probably take another 40mt mono.
 Then to the water where I made about 100 casts.
I LIKED:-
  • The cool appearance, strong looking and nice finish [/*]
  • Easy cast and nice free spool [/*]
  • Very smooth retrieve [/*]
  • Very effective adjustable cast control [/*]
  • Lightness for its size[/*]
    • It weighs 670gr fully loaded with line, against my smaller Saltist 40H at 751gr.
 I DID NOT LIKE:-
  • Large bulky appearance compared with my Diawa and Shimano 40’s
    • Its as wide as a 50 size reel, but the frame diameter is 0.4mm greater then my other Diawa’s
  • Noisy cast [/*]
  • Insufficient drag for my liking
Today [/b]I opened the left side plate to look at the inside and was impressed with the nice finish on the spool………the plastic bits look acceptable.
The spool is very heavy when compared to other reels and the reason can clearly be seen in the diameter of the material and shaft.   It all looks fairly robust.
What is interesting to me is the way they have constructed the mag system, which also explains the reason for the large frame.   Rather then adjust the magnets towards or away from the spool (horizontally), it move upwards (vertically) and completely away from the spool.   The magnets are also encased in a plastic container, a nice touch!
I LIKED:-
  • The solid appearance of the spool and shaft [/*]
  • Simple insides, easy dismantling
I DID NOT LIKE:-
  • The heavy spool and assembly. [/*]
  • Screw holding bearing in place……is functional, but looks like an afterthought.
    • 6mm diameter bolt/nut holding handle in place.[/*]
(to be continued[/b][/i])
Polychaete
(Continued a few days later)[/i][/b]
 I’ve made a few more casts with it, and unfortunately not caught a fish yet.
Today I opened it to see if I can find a reason for the noisy cast, and improve the drag a bit.
The first thing I noticed is that it is a completely different animal then the reels I’m used to, the whole right hand side containing all the working parts, detaches from the frame, not sure if this has any benefit, and you need to “hou kop” because you end up looking & working from a different angle then unusual.
Checked the bearing, all 100% and no obvious issues anywhere, with the exception of the clutch lever assembly that has too much play in it and will eventually cause a problem.  (I have this feeling about all the current clutch assemblies on reels, but they eventually all seem to last)
Then took the drag apart, looks like Carbontex washers (they call it something different).  All looks fairly robust.  I faced the metal plates which should improve drag a bit, a tiny lick of grease and re assembled.
Thus far I have no serious reservations about anything, the drag I’ll get the way I want it, the noisy cast is possibly the result of a heavy spool that is slightly out of balance.   I suppose I don’t like the unusual way of dismantling the reel, but perhaps it’s just a bit of resistance to change.  Once used to it, it could perhaps be easier to work on.  I am disappointed that it used different size bearings to what I have for my other reels.
I will report further after I’ve used it for some time or come across any problems.
Polychaete
"2 weeks later”[/i][/b]
I’ve now caught three Yellowtail with this reel and am happy with the drag and the reel’s pulling ability.   The drag washers are now completely dry and I did some more work on the plates; it’s smooth and strong now.
The noisy cast is still irritating me, and I can not find the cause without going to “extreme” measures witch I will eventually have to resort to.   I have noticed a small burr on the spool shaft under the pinion which may possibly be the culprit and will attempt to remove that.
I also had to use locktite on the clutch lever screw to keep it from working loose.
I will use the reel exclusively for a few weeks and work on finding the cause of the casting noise.
I am slowly getting closer to the cause of the casting “noise” or vibration which at this stage I suspect is caused by:
  • Unbalanced spool, not bent spindle [/*]
  • Poorly fitting bearings due to excessive play in the seats [/*]
  • Excessive flex in the graphite body of the reel [/*]
 I have managed to reduce the noise by half by wedging the bearings in their seats and removing the circlip from the one side of the spool.
I have also written to Okuma Support to see if they know about this issue and have a solution.
Maestro
Thanks 4 the review..i'm just curious to know that if the reel wasnt available in SA, couldnt u find 1 here that you could physically view thats suited your specs,cos from ur review,it appears that there r many dislikes...just curious
Polychaete
No, not available in S.A. yet.
Perhaps you are interpreting me incorrectly, but at this stage I am fairly neutral or uncertain about the reel, and if I can sort the casting issue I may well change to positive.   Also bear in mind that I actually state that it casts well, only noisy because of some vibration.
It has some good features,..........I would list some dislikes on most other well known brand reels as well.
I use it every day at the moment, so well see soon enough.
Polychaete
USD113- 00  About R1300 landed here with VAT and customs handling fees.
Just something else, I wrote to Okuma US & China to grumble about the casting noise that I've not yet found a solution for and asked their advice.
I straight away received a reply via their local agent Midas, offering to send me a replacement spool for the reel.
If that is an indication of the good service we can expect from them, then they will get my vote of confidence and support!:first::hapmad
Maestro
Wow, perhaps they read your thread here on sealine reg the dislikes of the reel,and decided to try and make up, lol, just kidding, sounds lyk gud service
Polychaete
In conclusion and summary of everything I've said above, my only serious gripe about the reel was that it made a terrible vibration and noise when casting.  The other dislikes I raised were more a matter of familiarity and the fact that its construction is very different
Okuma sent me a new replacement spool for the reel which is of slightly different design.   It has a bigger shoulder which I like, but most importantly, the casting noise is completely gone.
I have caught 4 Yellowtail with the reel, made about 4000 casts and can say it cast very well, the cast control is superb, the retrieve is as smooth as silk and all in all it works well.   The after sales service is great!
All that remains is for me to clock a lot more miles on the reel and see how it survives under serious fishing conditions.
I understand that the smaller brother of this reel is now available in S.A. and I would certainly consider purchasing another one should the need arise.  The selling price on the CR-303CS is R 1 117.00 INCL.VAT at Suburban.
Anyone that wants more info on this reel is welcome to ask me.
M@rius
Great report! Could you perhaps comment how it handles wading(swimming!) and do you think it can handle sharks? Thanks
Polychaete
The only time I do that is when I fall in the drink::rofl:
If it can pull Yellowtail, it can probably handle quite a bit.   I do not use very much drag though, so can't comment on sharks.
I am quite sure It could handle a 50kg YF tuna from a boat if your arms are up to it.
Ziyz
Which email addresses did you use?
.Junior
is this a good buy? how much mono would i get if i had 300m of .26 braid on?
how is this reel when handling big fish?
