okuma cerdos speed jig 601 mh for sharp tooth catfish
vaalriverhunter
Dag se aan amal ek is nuut op sealine dink dis n kwaai plek.wil net hoor of ek my okuma cerdos speed jig rod cj-s-601mh lure weight 3-6oz kan gebruik vir groot snorre of is hy te lig in die broek enige voorstelle. Sal wardeur word::slr::::slr::
Fishpaste
Hi VRH,
The rod will work no doubt but in my opinion is a little too short especially if there is a lot of snags in the water. I would prefer a longer rod so that your line can be lifted higher out of the water to try and eliminate potential snags. But your rod will work. Maybe pair it with a fast retrieve multiplier...
Oh and welcome to sealine! ::tight:
nobbles
Medium heavy is the perfect action on catfish. With it being able to cast that weight you should be fine. Agree with other post, off the bank you may battle a bit, along with not being able to have height on the retrieve if needed you will also loose leverage or pulling power ion the fish. But will be absolutely prefect off the boat. If butt section is longer than the forward grip this will also give you a good amount more power when fighting a fish off the boat.
