Noob question - Shock leader/slide etc.
steynt
I have recently bought a very nice Blue Marlin rod for sliding for eds. The rod is a WS 05/3 (It has three tips:6,7, and 8 ounce.)
I would however also like to use this rod for normal cast-bait fishing with say 4Oz sinker (Bait included perhaps 6Oz?)
I am paring this rod with a grinder, which I already owned. (It is a Penn Fierce 6000.) In hindsight this is not a suitable combination. (Rod obviously built for multiplier etc etc.)
i have managed to cast the 8 oz slide but as i grew in confidence, lost two sinkers (8oz) when the tip of the line snapped off.
I am using Kingfisher Giant abrasion 20lb, 0.35mm
My questions:
1. Do I just get a new Multiplier? If so which line should I spool it with?
2.Whether answer to 1 above is positive or negative, which length, thickness of shock leader is required with this very thin line I am using (I think it is 0.35, 20lb)?
3. I made a shock leader with 0.6mm Fluorocarbon and used the smooth leader knot but i am sure I am going to lose a guide as the clack-clack as the knot goes through the eyes cannot be normal..?
4. Would this rod be suitable for standard cast-bait fishing as well?
I would really be grateful if you could help with some suggestions/advice?
Rgds
Hooflyn 0.4mm
Keader 0.6mm
Probeer die knoop vir jou leader: Dit word sterk aanbeveel.
http://www.sealine.co.za/view_topic.php?id=41669&forum_id=44
Die leader is maar net daar om te verseker dat jy nie die lyn breek wanneer jy met 'n swaarder sinker ver gooi nie. Die dun hooflyn help weer dat jy kan verder gooi. Vir eetbare visse is die dun lyn goed genoeg, en met lae weerstand in die stroom en wind.
Die leader moet so twee keer die stoklengte wees sodat daar 'n paar windings van die leader op die katrol is wanneer jy gooi, sodat die dik lyn die krag van die aanvang van die gooi kan absorbeer.
Vir haaie is 'n dikker hooflyn nodig maar dan boet jy in op gooiafstand en hoeveelheid(meter) lyn op die katrol. Daarom gebruik die haaimanne braid onder op die katrol om baie meters op te sit met 150 m hooflyn van omtrent 0.47mm.
Hoe swaaarder die sinker hoe verder kan jy 'n grooter aas gooi, Dus hoe grooter die aas hoe swaarder die sinker.
Lees ook hier:
http://www.sealine.co.za/view_topic.php?id=85851&forum_id=1&highlight=line+management
http://www.sealine.co.za/view_topic.php?id=85850&forum_id=1&highlight=line+management
