Def-e-nition
It's been a long time since I've contributed , Hope everyone is well n dandy .
Certain life changes have forced me to divorce myself somewhat , from the Water.
in any event ,
I spoilt Myself last week , and Decided to take the plunge and ordered the Hc30 , From Nitecore .
I Raved About the H14 R , the 14.2 R was also pretty good - until I saw Alton off the point at Mazeppa , shining his Hc 90 straight down towards us , near Cable rock.
That was Enough to convince me to Look into the product. Nearly 2 years later - I discover the Hc 30 , and upon doing someresearch about the light , decided it was time .
The light is pretty well built , and aside from Not being bale to get it to go on from the word go , It Really is a hassle Free light to use.
the light takes one battery , and is sold with a a usb capable charger, called the f1 . Frankly I would've liked to be able to charge two batteries simultaneously , but for now , 1 is sufficient .
Is has 5 Modes : ultra low which is only meant for Reading , Low , Medium , high and turbo mode .
Hours for Each Setting , are: 330 H , 15 Hours, 7 , 3.5 hours, and on turbo Mode - 1 hour .
for General use, I am running it on the low seeting , as the medium setting is already bright enough to satisfy My requirements .
One big feature I enjoy over my H14 , is that it Weighs next to nothing,while also being simple To use, and as an added bonus- Waterproof as well .
When compared to anything smaller than an H14 , it is only the fact that The other beam is perhaps a narrowangle , where you might find something To compare .
It certainly isn't cheap by any measure- but all I can say is that when you spend that sort of cash on something , and have use for it - it Is , money well spent . This light is no Exception .
1000 Lumens is enough to literally Fill A Room , with light .
The Light cycles through it's Settings with the push of a button . to use the setting previously set ( medium , or Low light ) simply hold the buttn in while turning it Off. To go back to the memorized light setting, turn the light on by pushing the button down for 1 second . voila. Turbo Mode From wherever you currently have it in memory , is a simple Click away .
If you're Greedy, and Run it continuously on 1000 lumens , the light will only last for an hour - just What exactly you'd need to see on that brightness , for over an hour , is beyond me .
the light is comfortable on the head , due to it's light weight .
The headband , though a little large , is simple to adjust .
I also ordered a spare battery , to be charged Whiule The light is in use . This one is 3400 MaH , and will provide a few extra Minutes Worth of light , over the stock 3200Mah .
Trully and impressive, simple , expensive , but excellent headlamp . The light comes with a belt clip , to be used as a belt worn device, as the headband allows for the Light to Be slipped out of the strap , and used as a hand held Device .
Awesome Light . Highly impressive performance .
in any event ,
