New rod advice
drewpollard
Hi All.
I've been looking at getting a new rod. I'm interested in the Shimano Beast master. The technium would be great but is a bit too pricey. Been reading a lot on the forum but can't seem to get a solid answer to my question.
I've been invited to go shark fishing, and would like to use the new rod for the trip. But what I am unsure of is whether to get a heavy or medium rod? Basically, will I get away with a medium rod to catch sharks (and then still be able to use it for edibles), or do I have to go for a heavy rod?
Would much appreciate a one input.
drew
Splasher
drewpollard wrote:
Hi All.
drew
Hi,
If you want a solid response you have to list your concerns.
Like what weight sinker do you want to throw?
How strong are you will determine what strength rod you can handle?
Are you going to be sliding or throw bait?
One piece or three piece rod?
What is your budget?
To answer your question about if you can use a non ed rod for eds.
Answer: yes its just you going to find it an bit of an overkill.  But to use a ed rod for non eds you going to struggle a lot longer to land the shark.
The reason a heavier rod is chosen for non eds is to make the fight as short as possible to ensure that the shark does not die or become stressed.
I hope this helps.
drewpollard
Hi Splasher,
Thanks for responding. Answers to your questions as follows:
I'm comfortable casting 6-8 ounce sinkers
I consider myself fairly big and strong enough to cast a heavy rod ☺
Probably mostly throw bait, having never tried sliding
I would like a 3 piece (is there is disadvantage to this over the 1 piece)
R1.5k max budget
And I'm using a Tor30
Thanks again.
drew
Splasher
drewpollard wrote:
Hi Splasher,
R1.5k max budget
Thanks again.
drew
I found a three piece rod tends to wear on the joints when you slide alot.
A 7-8oz rod should be a good all rounder.
But see if you can get a rod that is T36 and higher as it will give you more backbone when fighting the non ed.
A rod is a very personal item, and chaps normally make the mistake of not wanting to spend alot of money and settle for an entry level rod.
But 3 months later after catching a few fish they sell and end up spending a lot more for a better rod that they should have bought in the first place.
See if you can strech your budget to R3k and get a custom DC Oval 4-7oz
Even though I dont own one its a "No Brainer" as it makes a great all rounder.
Redroman
I own a beastmaster heavy and have used it for the past 3 years now without any issues. Very nice rod and i even use mine for edibles with the 7-8 oz tip. i cast a 8oz for sliding on the heavy tip and easily a whole mackie with a 6 or 7 oz sinker.
Very good value for money rod, well back then i paid 1000 for it new. I've since changed the grip to shrink wrap and it gives the rod a great feel. If you have to stick to your budget i would say it's a good buy.
