Hi Guys,
I have been really getting into casting baits and experimenting with different combinations, mix grills etc.
2 big baits out on the slide and one on the cast ..... heaven.
I am casting a 6oz weed eater. Bait is normally a half mackerel, with a bit of prawn.
The problem that I am having is that when the bait hits the water, the force is pushing the bait up the line. When I reel it in, there is 10cm of line and then only the hook. (waste of time)
I am clipping the sinker onto the hook. I am trying to make the hook as proud as possible, so that the sinker does not push the bait up, but 8 times out of 10, it comes back stuffed. I have tried binding it really tight, but even that does not always work.
As you can see in the photo below, I even tried binding some float foam, above the bait, hoping that it would secure it. It kinda works, but also gets pushed up. ( a used a smaller hook on the day that I took this photo, just in case there was something smaller in the water)
Please guys, hows some tips, as I really enjoy casting - but at R5+ per bait, it is getting expensive.
Ps. as I wrote this and looked at the photo again, I just though that I could cable tie the bottom jaw to the line. I am not sure how well it will grip on the line, as there is quite alot of force.
pps. I am talking about casting the bait really far...really giving it stick.
I await the wisdom of my Sealine Friends.
