need help
sneaky ninja
Hi guys im goin in September up to the a lodge with my brother. not sure exactly sure where it is but about 3 hours drive out of livingston. we fishing for tigers during the barble run. now i know nuthing about tigers besides what iv read.
now my bro says i need to take 50pound line. which is think is a bit heavy. (im a light tackle saltwater fisherman)
i need advice on lure and line please. and then i also want to know if i can target them on top water lures.
thankin advance
hey ninja, we fished there a few years back. Sekoma lodge in the kasai channel with the barbel run. Great fun for flyfishing and conventional tackle alike. Altough i feel they like the flies slightly more.. Dont go without efzet double copper spoons and mepps tiger spinners. Believe me the cheaper copy op the mepps dont cut it! That braid is too heavy. We fished 30lb braid and it was more than enough!
BFC
Ninja,
Tigerfish are very good fighters , but they fight lekker and great fun on light tackle , the moment you start using heavy Saltwater tackle on them its a let down.
6,6-7ft MH- H , fast action rod.
reels:
4000 series shimano grinder ( FX-Stella are all good enough)
300/400 series Calcutta/Millionaire 5500-6500Ambasadeur size baitcasters.
I prefer normal nylon 12lb the stretch in the line keeps the lure from working loose,I Like braid for jigging and bass fishing but not tigers. If you get snagged in the river its easier to break loose/OFF. Make sure hooks are sticky sharp - carry a file and pliers
sneaky ninja
so if i roll with my gallie set up that should be good. 8ft vengence and 20 pound line i should be right in the ball park?
BFC
8ft Vengance is OK, 12lb line for distance casting
20lb mono to heavy. 4000 size shimano reel and youre good to go
Ed0101
During the barble run you will be mostly spinning with 20 to 30gr FZ’s or throwing lures from fairly close.  An 8 ft rod with 20 lb nylon may be a bit on the long/heavy side, 7 ft and 20 to 30lb braid being ideal.
Some top water spooks and Rapala X-Rap Walk lures would be great fun. Be sure to change the hooks and split-rings on them. I like 2/0 to 4/0 VMC Siwash hooks because of the large eye and the straight gape.
i have to agree with Ed. Also have the 8ft vengeance. Great for casting distance, not so much accuracy, and accuracy is what you want! Agree nylon stretches better, but that can easily be matched with a decent nylon leader on your braid.
