Need a reel but what??
Pylstert
@ Weedeater - Torium and Trini have the same drags, difference is frames and no of ball bearings
Also Skrops a Grandwave is fine and will last a long time if you don't fish a lot (like when you live in Benoni). If you live at the coast and fish every weekend, hmmmmmm not so sure how long a GW is going to hang in there. It's certainly not rated as a durable reel. A normal SL50 is much better in that regard.
You can't spend an hour or two every weekend to take your whole reel apart, often you only have time to rinse the thing off. That's when a Shimano works well.
skrops
about 30% of my fishing time is from rocks.
the point is, looks does not determine a reels lifespan. hell it does not even determine my life span.
fact is Diawa spare are readily available, so if they are that badly scratch you can replace them if you really have to.
skrops
 grrr pylstert you just had to bring Benoni into the eqaution.......:fbash
Pylstert
Doesn't Vernon Koekemoer also live in Benoni? He doesn't even need a reel to fish, he uses the sleaves of his shirts that he tears off.
Pylstert
yes the GW and SL50 will last 10yrs if you live inland, perhaps longer if you live in Benoni and Vernon services your reels. My SL50 is older than 10yrs but since I have moved to the coast the wear and tear has set in with the frequent use.
Mike Pike
vernon koekemoer does"nt even use his sleeves , he just tunes the sea back off bru ,walks in and collects the fish by hand.... Daiwa die hard fan Saltist 40 is good but then the Shimano are ok too its down to personal choice and what u feel comfortable with/and how often u are going to fish and what u target my 200000000000 zim$ worth.
willo
if u a dry water fisher try the grand wave reels,iv still got a 40 thats 15yrs old and never changed a part on it.... if u like to get wet and waid alot and want the hardest and probably the best priced reel use shimano 20/40.i tried the torium lasted 1 league season and gave endless shit,couldnt handle constantly getting wet and bits of sand getting in the gears(lots of waiding and yes it was serviced alot)every reel has its pro's and cons just decide whats best suited to your type of fishing...my 2cents
rofflign
[color=#006600]Walt[/color] wrote:
Hi Moss!You've come to the right place.What species will you be targetting?I only fish edibles and have same loomis rod as you and have just bought Daiwa Saltist 30H and can keep you posted once I've tried it which will probably be tomorrow if weather plays along.I've been using Daiwa X30SHV with my loomis and have been pleasantly surprised with this combo.I was fortunate to be offerred the opportunity by one of the members on this site to try this X30SHV reel prior to purchase and i suggest you try and do the same.You're welcome to try mine if you're out my way.I've been in that same predicament and with the help of Sealine members I've managed to make right choices.Cheers!
aaahhh Walt that's why your reel does'nt have the power handle,the SHA30, is the one that has it.
slater
I have a Loomis 12 foot and a grandwave 40. The reel might be a bit big for my set up but for yours it should be perfect. The reel has given no problems and am enjoying casting it.
Moss
Thanks for all posts! Bought the saltist 50H went out with it and i`m happy. Now it`s getting use to the rod and reel combination.
Moss
Thanks weedeater got braid on already. Kingfisher. We are going to slide this weekend and see what is coming out (weather permitting)
