My first lures
thenack
Here are some pic of my first resin lures. Turns out the clear resin is difucult to get right. But not too bad. I learned my lessons.
some don't have eyes yet. the eyes have a nice rattle noise when you shake the lure.
Also all of them have a tube through the middle meaning you can rig them with whatever leader you like. lure will slide along the leader.
I added quite a lot of weight in the back. Should cast well. One of the lures I added micro baloons to the one half and aluminum to the other so get the weigth. should be interesting to see that one swim.
Finally, popper with microbaloons in head and weight in tail. Should work quite well and make a lot of splash and bubbels.
thenack
I'm dying to give it a go, will try this wknd. Spent a lot of time thinking about what it actually has to do, and designed the thing accordingly.
the part of the mouth that will be in the water is narrower and deeper, catching a lot of water, and then the part above water is wider and shallow, hopefully making a big spray by forsing water from narrow deep pocket accros shallow wide surface (in theory).
I also made the "waist" thin and triangular giving less place to byte onto where the bottom hook is. the tail is also quite wide and should create a cavity when casting, redusing the drag on the botom hook, for further casting. this version did not come out smooth enough to see, but the surface has a "golf ball" effect wich should opefull also reduce air drag when casting.
a lot of ideas but my first mold came out very bubbly, had a moisture problem. I am going to make another mold of the model and hopefully get better results.
