My circle hook setup
This is my circle hook setup I'm going to try for some cob
-Eagle claw 7/0 circle hook
-Mustad 2/0
-0.65 mono hook snood
Make normal circle hook trace by snelling to the hook
I used Malin wire to thread shorter piece of mono through the center of the foam
Then attach circle hook trace to one end of mono/foam with fig8 knot
And attach smaller hook to other end of mono/foam n trim the tags
The small hook can be used to clip the bait to your sinker/grapnel and also hook small critters....
DJP
Looks interesting and will catch fish, I normally do the hooks the other way around with the circle at the bottom and J hook on top. The reason for using a circle is that it hooks up in the corner of the mouth if you have a small J hook at the end I would presume that you will be gut hooking a lot of fish, especially undersize ones, not conducive for safely releasing your catch. Just a comment nothing personal.
I never actually thought about the gut hooking scenario...
Thanks tho, no offence taken
Kaashief
I have noticed tho that when using the skelme hoek tactic the fish takes the top hoek +/- 7 out of 10 times
thanx for the tip defnitely gna try this setup
