monohull boat
Zambuca
hi.im better now when it come s to posting on sealine.im reli new to boating .just bought a boat with 2x40hps yamaha s but to my dissapointment its not awetdeck so any 1 help me on this .how do you rate a boat for the sea .i was under the impression that a sea going boat shud have 2 motors and so on.
robyosh
SEEMS TO ME YOUR CONFIDANCE AND MINE ARE THE SAME WHEN IT COME TO THE SEA I ALSO LIKE HAVING 2 MOTORS
THE BOAT LOOKS GREAT
Zambuca
lmao .ok now how bout some advice on a steady sea boat.how much should i raise the deck .
FRITZABU
If your boat float on the water. Get the water line and fit your deck above the water line. With out lets that is also above the water line but level with your deck.
See the photo I load . You will see the scupper by the left rear corner on the transom .
barryfish
Zam your boat has scuppers on the transom, low perhaps below waterline, but they are there? must be wet deck>
FRITZABU
I also did see them there ,but could not make out clearly ,if it was not something else ? maybe the glasses getting old !!
Zambuca
hi .yes it has.but the deck has 2 levels like a little step.the front deck has a high level than towrds the back.hope thats not a problem though.its registered for 15nm
FRITZABU
Yes now I can see them clearly.
Your boat should be fine !!
Its possible that they originally raised the front deck, to enable the water to run off much better. If you would get water on the deck .
Enjoy :fishn
Zambuca
thanks for the help.judjing by the shape what do think of its stability on the water havnt taken it out to sea as yet.cheers
FRITZABU
Hi any boat has its own caractor on water. Just take it easy when you use it for the first few times. Get use to how it handle and with any mono I prefer not to have any heavy weight in the nose section.
You also have to be wakeup in a following sea as 'n mono broach different to a cat and you may get a big freight when it feel like it is tipping over.
I have found that with the nose very light. It come out of the hole much easier than when its very heavy.
A friend of mine had similar boat for many years and enjoyed it very much.
