Min kota problem
Sharky_Too
Hi Guys, my min kota edge is rotating the wrong way. It is leading with the prop and not with the cone. Any advice would be most welcome as i am at the dam and need it for tomorrows fishing!
Sharky_Too
Thanks I found the problem. The housing for the motor needed to be turned 180 degrees to reverse the polarity. That sorted the problem! I did check the wires and they were all good.
