Lure fishing
Arno Nel
HI All
I am new to lure fishing and I am considering to get my self the following rig.
Shimano Sarogosa 5000 loaded with 20lb briad
Custom build CD oval 10.6" from Rod Worx
I will be targeting Garick, Shad and Kobs
What do you all think
DavePE
Hi Arno,
I think that will be a great setup. I've got the Saragosa 6000SW. I would go with the 6k for a bit more line capacity. Same weight and size as the 5000SW. You're unlikely to need it while spinning but you could still use it as a deep sea boat reel. At least that was my thinking going for the 6k.
The reel is quite a bit heavier than my Stradic 5000FJ. But I think having a waterproof reel is worth the extra weight.
Load your reel up with Suffix 832 20lb and you're good to go.
Arno Nel
Got my reel yesterday.
Now I need to make a plan to go and see Mark to buil my a rod
My mind seems to be made up on the dc oval 10'6"
IWyk
DC Oval 10'6 is a awesome rod. 3/4-3 ounce casts a mile.
You may also want to consider a Shimano Ultegra 5500, contrary to popular belief they where actually designed for salt water angling. They also have a special long cast spool and are well priced considering what you get.
You also get a extra spare spool with it, which gives you more options on line.
If put together by a pro rod builder(Enigma built mine) with the right guides this combination casts a mile, I have such a combo as well as a 12'6 Oval DC with the same reel, I prefer the 10'6.
For the mentioned fish you will be targeting the Ultegra is more than enough reel and will outcast the Gosa and Stradic.
Enigma stripped and compared the Ultegra to the Bullseye and it was an eye opener.
I was lucky to read this before I bought and I am extremely happy that I got a Ultegra XSC 5500. So happy that I am planning to get a Ultegra XSC 14000 for a bigger ed's bait set-up.
Before you finally decide read the post at below link and then you can decide for yourself.
http://www.sealine.co.za/view_topic.php?id=85766&forum_id=1&highlight=bullseye+vs+ultegra
Arno Nel
My 10'6 dc oval has been orderd from Mark ( Rod Worx ). Now the wait begins
Will load my braid onto my Sarogosa 5000 so long and prep my lures.
Should be able to collect my rod in the 2nd week in March when I am back in the country
