Lost at sea
Rudolf
Seasafe has been developed over a
period of five years in response to a growing
international demand for a PERSONAL “self-contained”
and “stand-alone” tracking and
location system. Seasafe has been designed to
supplement and complement existing tracking
and location technologies. Seasafe has addressed
very specific issues such as;
  • Tracking accuracy[/*]
  • Time taken to respond[/*]
  • Signal transmission ranges[/*]
  • Transmitter battery life once activated
The ultimate benefit of the Seasafe system is the ability to react immediately
to critical or non-critical emergencies at vessel level without invoking or waiting
for National or International Search & Rescue authority response. Often marine
activities take place outside of traditional National and International Search
& Rescue Authority boundaries and may be inaccessible to authorities. In the
event of an emergency occurring in a remote location, using  Seasafe, crews are
able to react instantaneously and to effect their own search and rescue.
The time taken to respond to an emergency is extremely critical, particularly in cold or shark infested waters.
Seasafe Operational Overview
Once activated, the Seasafe personal transmitter may continue
to transmit for up to seven days. Signal transmission duration
is dependent on the condition of the battery and whether the
transmitter has previously been activated. The radio frequency
signal emitted by the transmitter will be received by any land or
water based receivers which are within range. Signal transmission
ranges may be affected by a number of conditions including
prevailing weather conditions, cloud cover and line-of-sight
obstructions.
Real-life trials indicate possible transmission ranges of the
following order:
Water to boat Up to 30km
Water to base station Up to 40km with 15m high antenna
From water to aircraft at 1500m Up to 100km
Seasafe “Personal Locator Beacons” are an AID to rescue
only. They do not guarantee your safety. This at all times
remains the responsibility of the individual.
For more information contact:
Rudolf  072 326 8422
E-Mail: erb@telkomsa.net[size=][/size]
We use the global technics VMS at R270 per month, This is monitored by MCM and can pinpoint you on the spot, I think they use google earth as they told me how i was driving when i tested mine.
miles
srandwolf, the vms system is not a safety feature, but rather a way for MCM to control the movements of commercial boats.
Should a vessel fitted with a vms system capsize, sink or have an electrical fire, the vms system is will not function. I think the vms 'reports' the vessels movement every 15 minutes, so at least rescuers will know WHERE to start looking, assuming they've been alerted.
Last year, when the commercial tuna vessel "Shaka" sank in the deep, the last known co-ordinates were taken from the vms reading  just before she sank. Even with the known last co-ordinates, it took most of the commercial tuna fleet a few hours to find the survivors.
With EPIRBS's and any stand alone unit like mentioned above, the authorities will know IMMEDIATELY when you've sent a mayday and can respond. They then also have an EXACT location of where you are.
tkei
Miles, Do all commercial boats (Particularly the bigger trawler type) have to have VMS on their boats, and do they have to be switched on all the time? reson I ask is that here in EL area, a few tuna boats that have to be 10 miles off shore have been photographed withing a few of the reserves around EL and Kei mouth, but their VMS's have not been on a tthe time according to MCM. What is the punishment for a commercial if this isnt on when it should be?
miles
Hiya
tkei, when we put to sea, our vms MUST be switched on. Upon leaving the harbour, we also have to inform the local sea fisheries officer, in my case, Pat Stacey at Kalk Bay harbour, of what time we're leaving and when we're returning. This is done via sms. Upon return, the sea fisheries officer can then inspect your catch, should they want to.
The rule is that your vms MUST remain on at all times when at sea. Should your vms fail, for what-ever reason, you must contact MCM and inform them and return to port immediately.
Unfortunately, MCM doesn't have sufficeint man-power to monitor all vessels. Its a real pity, becuase they have the technology but not the man-power.
In reality, i've pretty much lost faith in MCM's ability to control rampant poaching. Their fines are a joke and they really don't put enough effort into enforcing the law......
