Johan Fourie
Hallo Bennie - no, me and Mikey have sorted this out. The "seep holes" inside the box are 1/2" and the drain hole on the "over flow box" is 50mm - as you can see on the posted photos the drain is situated in the lower part of the overflow box - nothing gets clogged - there is a normal drain plug to drain the bulk of the water - the livewell works like a charm.
