live bait rig for tiger
zakariya
Hi guys!Do any of you guys know how to rig a live bream or bulldog for tigers?Also how do you set your drag?and when do you stike if you do?Thanks.
Kona
Hi Zakariya
I use a circle hook with all my live bait so no need for a strike. No drag if the tiger feels drag the chance of dropping the bait is good so try free spool as much as possible. I will try post a picture of how I rig my live bait later. So the idea is once the tiger starts free spooling you give him some time to eat the bait then put pressure onto the line to set the hook (no strike). Remember that you are not striking so your hooks need to be sharp to help set the hook.
zakariya
Thanks bro!What size and make of circle hooks are you using!and if you could do a sketch i will really appricate it.Can these also be used on a dead bait because more often then not these baits are bought dead from the locals.thanks again!
Ryan
I would go weightless with a bit of Piano wire 2/0 hook. Hook it just under the dorsal fin. Cast up into the current and drift.
If the current is too strong then use the smallest ball sinker you can find to get it down.
With Live bait small ball sinker hook the live bait through the Anal fin the sinker will pull it down and the fish will swim up.
Hope this makes sense
Ryan
Tigers are clean fighters - meaning they are unlikely to wrap you.
Your drag needs to be loose enough not to loose all your string and the reel needs to be fast enought that in the event the fish swims towards you - you can keep up.
Rather than a heavy strike buy the sharpest hooks that you can - we used to catch tigers on 6lb line and there is no way you can hit him hard the hooks needs to do the work
zakariya
Ryan do you have a sketch of how to make up this rig?Thanks for all the info bro!Normaly we use a 22inch halco trace with a small sinker and a 5/0 gamagatsu long shank thin gauge hook.threaded trought the headd and tummy and embedded in the tail!we fish a semi loose drag and when the fish really starts to take line of we just start reeling in.but the ratio is still roughly 2 out of 10.
Ryan
Firstly Use Single hooks no double rigs etc.
I use 20cm of the smallest Piano wire I can find.
5/0 Gammi's - I like the Trey Combs Gammies.
Smallest power swivel I can buy and a small ball sinker.
Sorry no photies.
Hook the fish just in front of the dorsal fin through just enough flesh that the bait lies in the bend of the hook.
Rember a tiger swallows it's prey head first so this will help with the hookset
Ryan
Uhm tigers don't like drag when drifting.
Try using Baitrunners alternativley Freespool a multiplyier with your thumb on the drag
FREE THE FIGHTER
Hi Zak
My take on it - when fishing live bait for tiger the general idea is to let her swallow it.
With bream livies your hook up ratio should be pretty high and a lot better than 20% - my guess is you are pulling  too soon and too hard. Agree 100% with Ryan on the hook placement - no need to thread through stomach etc,etc. Some guys like to hook through the lower lip coz the bait swims better.  Me not. I hook it same as Ryan. I feel you must hook it so as not to impede the bait getting down the throat. A descent sized bream will generally get stuck in the stomach/throat as the sharp fins will get stuck as you put pressure -  so the brem is your hook. The hook sometimes hooks in the stomach lining - too much pressure/drag and the hook will rip out and may rehook in the throat/mouth or maybe not !
I would prefer a longer trace than 20 cm as a big fish that swallows it completely may leave very little space to the  swivel/line - say 30cm. When she picks it up I prefer to free spool with a multiplier as the better fish when finicky tend to drop it if they feel any resistance ( baitrunner). Free spool for as long as possible, then have a sip of your beer/cooldrink, then light a ciggy, then free spool some more. She will somtimes jump while you still in free spool thenyou got no choice but to start reeling she has felt a prick. She will now be miles from the boat so a strike is largely irrelavent - huge bow in the line and the stretch will do nothing. Just reel and keep the pressure on.
Not too much drag ! Gently does it. Most lost Tiger are through guys fishing them too hard. The adrenalin gets the better of us. When she sees the boat she will start to hassle a bit but patience !!
Just my 2 cents - hope it helps Zak.
Hope you well Ryan !!
zakariya
Thank you so much for that!The skippers that take us out on the boat usually say that you must leave the drag fairly open but not completly.Then you allow her to run and as shes running(for as long as possible) you just start reeling in.You fight them very gentle!Only difference from your tech is that we use to buy bait from the localls which usually was silver barbel most were already dead and all were about 15-20 cm.What would be the best bait?what type of hook?what size hook?sinker or no sinker?i know im asking alot of ques.Thanks really appreciate it!
FREE THE FIGHTER
No problem at all Zak. I assume you are referring to fishing on the Zambezi as I see this your favourite spot.
I think that maybe the skippers who are saying keep a slight bit of tension on the line have seen some guys getting overwinds/backlash maybe on multipliers hence the advice !! Have seen guys fish with spinning reels like this with the bail arm open and simply holding the line with their fingers then relaesing it when she picks it up. Simply engage when you ready.  As I said if the fish are really aggressive they wont really worry about a bit of resistance - but if fussy will drop it - especially the big ones !! They didnt get large but being stupid and careless !!
Hook size would vary according to bait size. I use straight shank Gammies anywhere between a 2/0 and 4/0. When fishing with very small " live" bait - free spooling not always necessary - similar to using a fillet - very sharp 2/0 hook and 10 lb line should be fine. Heavier baits like a palm size bream - she needs to swallow it and it takes a bit more time. 14 lb and 4/0. All monofilament .  If the wind is up and on the Zam it is always blowing against the current your bait will sit on top so need a sinker large enough to get it down a bit. Too large a sinker and if it is bouncing on the bottom it will snag up quite a bit and you  lose lots of tackle. Also the lighter lines will get down better obviously.
Tiger are funny though - one day you will really think you have them sorted and the next day they will have you sorted. At certain times they will not touch a live bait - only very small fillets ( chessa). Other times they will smash livies and not touch fillet. Somtimes they will santch at it and drop it very quickly - other times they will keep coming back at it if you miss them first time. So there is no perfect bait or livie - if its working its good. But when using fillets definitely the fresher the bait the better - if you've pulled it for an hour or so all the oils will be washed out so change it.
Nowadays I prefer to fish mainly with fillet with 2/0 hook and no free spooling - light drag and she's on or off. I feel that when free spooling they swim away from the shoal - if you miss her you dont get a second pick up - usually from another fish. When not free spooling you keep your bait in the shoal - often first fish may not get vas but another one will pick it up. I am refering to fillet or small livies ( two finger size).
Hope I am not contradicting myself ????
Also hook must sit clear of the bait - not like sea fishing where you wrap with cotton - or indeed like you were threading the trace through the livie.  As Ryan says the hook must just hold the livie or fillet, no more !
zakariya
Wow that makes aloto sense.I am fishing on the zambezi gona be leaving tomorrow,im fishing the waters close to katima mulilo.Will def be usin all of your advice!Whats your take on circle hooks?
FREE THE FIGHTER
As I say - keep an open mind. Again circles can be fantastic but they can be duds ! In my experience the fish must be slightly heavier to be effective - i.e fish over about 7 pounds.
I use them sometimes with a slightly larger fillet or what we call a "cutlet" - cut straight through the body of a chessa say. With the circle I would fish them  more like the skipper was telling you - light drag and once he's really moving with it start to tighten the drag slowly. She must be moving quickly so there is good pressure to sink the point of the hook. When its working you will get them virtually every time !!! Ang the nice thing is she will get hooked in the corner of the mouth in that hard plate there - and you can then fish her nice and hard. As a result she will jump more and you have great fun feeling the power of the fish with full confidence that because your hook is so well set she wont come off.
You dont need to let her swallow it completely - so long as she is running away from you at fair speed it should set. If she runs too far you wont be able to get enogh presssure on to sink the hook - too much bow and stretch in the line ! Slightly heavier tackle for this - I use one of  my bass reels ( Shimano Curado). It has a star drag so just slowly turn it up - you will soon feel once she is on properly and she will probably jump. Spinning reel will work fine also of course and the sound of the drag when shes running will also tell you when shes moving nicely and ready fro the hook set. Also use the cirlces with thinner wire - not those thick black ones - sorry dont know the brands - Mustads I think. Forgotten the size too - sorry !!
Also with circles defintely use paino wire not platic coated or that multi braided stuff. The reason being that as you pull the hook forwand the piano wire pulls smoothly through its teeth so hook settles nicely in the corner, the other can fray and stick it the teeth - she then opens the mouth and is free !! Also a nice smooth connection wire to hook - not snap swivels !
Stiffer action rod - I use a  medium heavy 7 foot rod for this ( again one of my bass rod) - too soft a rod as you would use with the other methods and there wont be enough pressure to sink the hook. Mine is a Fenwick but most rods are fine - Shimano Crucial also nice. When she is closer to the boat maybe loosen up the drag a little. And the release is easy - pair of long nosed pliers and grab the hook with the fish still in the water and viola off she goes.
And of course NO striking - just keep the rod up and tighten the drag.
If the fish are snatching at the bait and do short runs circles dont really work. Go with the normal sharp 2/0 so she gets on asap. Also i dont think circles work or are necessary with bigger live bait - thats another long story though.
Good luck and have a great trip !!! I hope I haven't confused the hell out of you.  Keep trying different methods but it all seriousness when you are on fire you should get right up to 90 % hook up and land rates.
