Alvey 500 to 650 range of sidecast reels. KP(Scarborough SA made) far cast deluxe in sizes 4 1/2', 5' or 5 1/2'Far Cast Reels: These are reels that have duel pins on the bracket , you clip the drum off the side pin and clip the drum on the top pin to cast the reel, and then return it to the side pin when finished casting. These reels are extremely efficient in estuaries and are suitable for beginners and new users of KP Reels as they cast the same as coffee grinders. Also known as "Komkyk" reels.
Rods would be anything from 10-12 ft. You may want to move the guides to prevent casting issues. First guide should be about halfway up the rod due to the large diameter of the spools.
Contrary to popular belief the first guide/eye does not need to be of large diameter, a Fuji Lowrider works like a bom.
If you prefer to go for the fixed type of center pin(where you cannot remove the spool for casting), prepare for a lot of practice and frustration. You will also be better off with a parabolic fiberglass rod rather than a quick taper graphite such as a Purglas(Yes still available in fiberglass). The far cast models make casting easy and frustration free and you have all the other benefits of the center pin reel.
