Leader Knots
G
Guest
Guest
:fswim
Hey Guys
Plz could you inform me on whats the best?strongest and preferably the smallest knot to use when joining leader to nylon, how much and when should i require leader line. I have used various leaders before but seem to get a heavy bunch up after a few casts.:cry1
P.S i do have a brief idea with regards to the casting distance and stregnth but need a little advice with the above^
Regards
AB
Noweeds
The best method for leaders is a bimini twist on your mainline, leaving three strands. Then use double figure 8's to join this two your leader.
I always fish with a leader and the thickness is determined by your quarry and where you are fishing........for example for large non-eds i use 1.3mm Perlon and for edibles down to .7mm
I've always used Araty for my leaders but this is now off the market and therefore i am going to have to experiment when my stock runs out, but i reckon that i will move over to perlon!!
shavs
hey weeds
can you briefly explain the advantages/disadvantages of using three strands as compared to two strands from your bimini.
regards
shaveen
Noweeds
If you use two strands it means that one strand needs to be tied off......with three strands every tag end is tied into the fig of 8 and there is zero chance of any weak links!!
