Lead heads diy
CrAZy-BuG
tauruck wrote:
I've never seen such a furore over drilling a little hole in lead.
Boys!!!!::S You're breaking my heart.
You should see us go when we have to paint a security gate!
On a serious note though, I have drilled into soft things before and usually it would cause drill bits to grab/break off. That is why I had the question.
Mango
Will101 because you are not using a hammer drill or a drill set to hammer you dont get the chisel affect you are indirectly using a drill with a cutting angle that is a lot less than a normal drill bit .Same pricapal used when drilling copper that is known for braking bits
Give it a try you might be surprised
Mango
Crazy the softer the material you are drilling the less off the material you want to pickup/Bite into with the drill bit .If you can sharpen your own bits you can save your self a lot off trouble with bits breaking
Limpopoking
Drilling lead IS actually particularly difficult. More so in the smaller diam bits 2-4mm. They break off damn easily. Slow speed & lotsa lube. I found this out making my own grapnels. I've never tried using the TCT bits mentioned above (masonary bits) but yep, they have clearance between cutting edge and body so will probably work. My 5c :blah
