Kob Trolling
AD97
Just bought the third Alcocks DVD recently. The footage is AWESOME, absolutely brilliant.
Since the Eastern Cape, and specifically the Rivers and surf around Kenton and Port Alfred is where I do most of my fishing, the Alcocks DVD inspired me to say the least.
We have only recently started trolling in the Kariega and other rivers in that part of the world. We havent been succesful as yet- we mainly troll up to where we anchor over holes where we fish and then take a slow troll back to the slipway. I have recently purchased a few Halco lures to specifically target the Kob in those rivers.
From the Alcocks DVD I have picked up the following:
1) Ideal trolling speed- 6-7 knots
2) Ideal times- Early morning/ overcast days
3) Ideal tide- 3 hrs before spring high onto spring high
4) Smaller size lures in summer and larger size lures in winter.
5) Colours- Mainly Purple, then Greens and Golds. Then one "Magic" colour.
Thats what I've picked up.
Do the regular EC Kob trollers have any other info to share?
Thanks guys
AD
fedu
Not an EC troller, but have caught a couple hundred kobs trolling and I would say that most important is controlling the trolling depth of your lures.
I wrote several post on sealine abou kob trolling with artificial lures try search.
I use deep diving lures and depending on the depth I am trolling I give or take more line, different depths will also mean different lures, I like to have my lures running very near the bottom and I do not worry if from time to time they harvest the ground.
P.S. - I use braid line to allow deep diver lures to dive deep
SPIN A HOLIC
Howzit. Just some pointers to help you.
1) 6 to 7 knots. Much to fast. That's the speed we troll for yellow fins for 40 miles out to sea. Put the lures you choose to use in the water and put the boat into gear. Let it about 1 meter out and watch the swimming action. All lures will swim differently, even the same two lures might not have the same action. Usually the moter just ingear will do the trick. The lures must just swim nicely.
2) Kob will feed any time of the day. Whether its early morning, afternoon or late evening. Even at night they feed. Its tide related and trolling the right place at the right time.
3) Even the outgoing tide can produce fish. Its dependent on river conditions as well as frontal systems and water temperature.
4) Lures size can be more dependant on the depth of water you are fishing and the size fish in the area. Eg, you won't troll a 18cm floating rapala in 1.5m of water or a halco 3m plus. You would tend to go for smaller lure like a bomber or a 1ft minus manns. And big fish can enter a system any time of the year and small fish remain in the system untill they reach a certain size so one can target small fish the whole season but perseverance for bigger fish will pay off.
5) Colour could work some days but most days any colour could do the job. Its upto the depth and action or speed you are trolling you're lure at.
But confidence playes a huge roll. If you got you're first fish on a purple shad rap the chances are you're next couple of trips you would use that same lure and just because its worked for you in the past.
PS. I actually hate trolling and would rather drift and catch these fish spinning on a plastic. LOL.
Macleod
The Alcocks DVD is really awesome. And its great to take tips from all their years of experience. But my suggestion is, put in as many hours as your lifestyle allows and figure the right tide, temp, pressure etc for the systems you frequent. The reward is awesome to figure these things out by trial and error. To me, the most fun is making an effort to fish, and it eventually pays off. Then after some years, the catch rate increases with every trip as you have figured out what works, why and when...
Guys like SPIN and the Alcocks and many more experienced anglers on our forum had to do it this way in the past as there was not much advice back then.
As for trolling, I am useless as I hardly troll but this year, I WILL catch some bus cob^^..
AD97
Thanks for the help so far guys. Was actually watching the 1st DVD just now. Chad says they fish seasons and goes on to say that they catch smaller fish earlier in the season, bigger fish later on and then later still the leeries come.
When is the seasons that he is talking about. What months?
Thanks for all the help.
SPIN A HOLIC
he would be referring to the winter months as peak season but our rivers produce quality fish all year round. I've landed a lot of fish in the 40lbs mark in the summer months and I'm sure most guys would regard that as a big fish. Not a 80pounder but hey, beggers carnt be choosy. Ill take any size cob on any day as its better than catching nothing.
AD97
Thanks Spin. Are there any particular months that are best. We normally head down to Cannon in a July and December.
Bushbuck
trying breede next weekend. u guys found any difference with trawling with or against the current. this would obviously have an effect on the speed too.
any other tips generally that is should be aware of?
Tim Allan
Can you maybe give me some tips on fishing for Kob with plastics? I do my fishing in the Breede river and am looking to start targeting Kob on soft plastics.
BoomBoom
Most of us down here in the EC use McArthy Plastics and they work great.
The conditions (wind\current etc) will play a major factor when choosing which size Jighead to use with your plastic as well as the size of the plasic. We mostly use around 1/2oz , but I have even used 1oz in rivers . 5inch McArthy's should do the trick
Depending on the structure u gonna fish - try fish slowwer for Cob with plastics , therefore fishing near the bottom.
Also try changing colours of plastics if things are slow...
Fish finder will also help a great deal
Carlos Moran
The conditions (windcurrent etc) will play a major factor when choosing which size Jighead to use with your plastic as well as the size of the plasic. We mostly use around 1/2oz , but I have even used 1oz in rivers . 5inch McArthy's should do the trick
Also start off fishing the known ''hot'' spots for cob,try not to use an anchor at all,youll cover lots more water and take note of where you get bites/hookups.Cobs are shouling fish by nature.Fish the lightest jighead possible,but always have contact with your lure and you must be bouncing off the bottom.
subaruseun
foamy sections and oil slicks reveal the deeper water below where the channels are ...
foam = harders feeding/hiding = cob
spooked harders = geelbek working in the area
check the direction of the current and position yourself in line with the current drifting away from you.
throw a bait line on float in the current about 2 fathoms deep (3.6m)5-10-15m away, cast in this direction past your float bait and jig your drop-shot or lure past this floating bait... you will get more hits.
try the texas rig if you loose to many dropshot when bouncing off the bottom.
