Kilwa Ruins
GL
I am a new member to Sealine and am going to Kilwa Ruins, Tanzania in Feb 2008.
Can anyone advise me on what type of fishing is the most productive at Kilwa e.g. plugging, vertical jigging, drift baiting, etc.
Often fish at Bazaruto so want to know what similarities there are between Baz and Kilwa.
What tackel is suitable for Kilwa as use I normally use following at Baz:
Trinidad 30 reel with 30lb braid/Shimano Butterfly Rod rig for vertical jigging;
Stella 8000 with 50lb braid/Shimano 8ft Rod for drift baiting and plugging
Stella 4000 with 12lb braid/Shimano 10ft Rod for drop shotting;
Saltiga with 35lb Siglon/Assasin HMG (L & M) for surf fishing;
Big Trinidad with 50lb Siglon for trolling;
GL :welcomesea:and allow me to say, impressive gear you've mentioned, hmmm what your occupation, better yet where do you stay? hmmmmm? Just kidding, and also I don't know anything about that type of fishing you've mentioned, just wanted to welcome you to Sealine and hope that you'll get what we are all addicted to, the friendship, knowledge and the obssesion of being part of Sealine......
Welcome again Bud.
:f1shy
Hey Big G, Welcome to the club! Its about time!
I know squat about Kilwa, but there was quite a bit of info in the ESA mags??
I see you use Siglon line for R/S... best you don't use it in Transkei off the Rocks... it has a reputation of having very poor abrasion resistance!? It's excellent for beach/sand fishing, but not for structure or for sliding...
Nepptune
GL
First off - Welcome!
Second off - We're all jealous!
Thirdly - Nice Gear!!
Fourthly:
Jigging - Beef your jigging set up up with 65 to 85 lb Braid... 30lb isn't gonna cut it... you gonna just be losing expensive jigs left right and centre! There are some BIG nunnu's in those waters!!!
Take lots of poppers... you'll lose a bunch.
Thats my info so far.....
GL
Reefman,
Thats why I use Fluro for lead as well! Have filled 30H with 0.4mm Double X. Thanks for advice.
Green Fish, thanks for note. Luckily my wife thinks the kit is sponsored by low budget fishing shop cos reels are spraypainted gold!
Nepptune
You could also contact Kilwa Ruins Lodge, speak to Jonathan Snooke, he's a SA boy skippering up there, and I'm sure he can supply you with a good equipment and target list...
GL
Hey Neptune, what poppers did you use . . . Carpenter, etc? Do you have any advice or pics of poppers/jigs?
What gave most productive results . . jigging /popping/drifting?
Nepptune
GL - Unfortunately I've never fished there mate, but I am on a few other international boards where there are guys from all over who fish there ALOT!
Jigs - I'd take a mix of long and short jigs... All depends on the water depth you fishing... you wanna be able to hit those deep reefs for Dogtooth, so the long jigs will be good for that...
The shorter wider jigs will come in handy over the shallower reefs for Grouper, Snapper, GT's, Jobfish etc...
Poppers - You want poppers that are gonna push ALOT of water... You need to make as much noise as possible to get those GT's up off the reefs. Brand wise there are huge numbers to choose from... just be sure they are through wired, and change out the split rings for STRONG ones, as well as the Trebles... don't go cheap on hooks mate, no point in spending big dollar on rods, reels, line, flights, boats, accommodation etc, and cheaping on the hooks and having your dream fish crush them and spit them out like soldering wire!!!
I think jigging is dangerously effective, but popping is gonna give you the surface strikes, which is about as cool as fishing gets!!!
Try both.... from what I've heard, be prepared to put in LONG hours in the blazing sun.... You only there for a limited time, so make the most of it! Fish HARD, and you will reap the rewards BIG TIME!!!
Check out this thread.... Just a little something to whet the appetite! :)
http://www.deepjigging.com/showthread.php?t=545
GL
Brilliant link Neptune!!
Pics of Kilwa fish are very similar to Baz . . . Gt's, Blue Fin, Snapper, Job, etc.
79 days to go!
Nepptune
Wicked man, no doubt its gonna be an epic trip!!!
If you take me along in your suitcase I'll bring me Stella 20k, 10k and 6k, along with my Smith S56LH and Tuna Max S57XXH Jigging rods and Shimano 8ft Popping road for you to use, and my pile of Jigs!!! :) :) :)!!!
Make sure you take LOTS of pics!!
If you need any gear, I'm talking top jigging and popping gear, speak to Randy at www.anglers-proshop.com .
Just be careful, there are soooo many things on there you will want, and your pockets will get thin VERY quickly!!!
