just bought a boat....what now?
swannie696969
Hi guys...
I wonder if anybody can help. looking into buying a boat ....Baronet. just for cruising around with the family. found a boat but does not have Boyancy or COF.
What would the costs be more or less to get both done?
then the boat has a mercury 85 engine. is this considered to be a decent engine and is it sufficient to power a baronet?
any comments will be appreciated
thank you
Swannie
QuQ
Buoyancy and COF will cost you 1000's. The deck will need to be ripped up etc. You are better off looking for a boat that already has a valid buoyancy and COF. 85hp on a 17ft for cruising around is plenty.
JVW
Swannie,did you buy,or are you thinking of buying.
Ek stel voor jy luister na die manne se raad-hulle weet waarvan hulle praat.
swannie696969
Hi JVW
I haven't bought the boat yet but i have first option.
Any advice would be helpfull.
Have to do boyancy and cof. Want to use on dams.
rianc
Dis regtig nie so helse effort om 30% bouyancy in die boot te kry nie. Ek het my Interceptor 18,6 ft gedoen sonder om die vloer te lig. As die boot mooi, goeie toestand, vat hom. Die COF inspeksie gaan jou, sonder jou veiligheids toerusting, beloop sowar R450, bouyancy insluitend sertifikaat sowat R2500. So onderhandel maar met die verkoper.
Rianc
Lacost
rather buy a boat ready to go. If the boat has not got boyancy certificate it has not seen water for some time not a good start
..Chillax..
I have recently done my 14ft sportsman for R1400, obviously the 17ft will be a bit more, but not drastically.  The COF is just a survey and wouldnt cost you more than R400. That is if you have all the required safety equipment.  If not this can get a bit pricey.
As aqua said, you will have to do your cat R skippers license.
It is all worth it in the end. Just Do It!((s((peed)
thika
What about the trailer?
This could become more of a hassle than the boat if you don't have papers
Psy
The law has changed!
You dont need to RIP UP THE DECK!!
"Documenting built-in buoyancy (Buoyancy certificates)
General
What is really important is that the regulations require that owners be able to demonstrate to a surveyor, safety officer or any enforcement officer (SAPS, municipal police or other designated enforcement officer) that their vessel complies with the regulations which include the buoyancy standards.
As the provision of adequate buoyancy aboard small vessels is so important, it is very likely that owners arriving at any launch site may be asked to show that their vessels comply before being allowed to launch.
The only way to do this at short notice, without a great deal of trouble, is by carrying and producing the valid buoyancy certificate required by Annex 1 of the regulations."
"The form of the Buoyancy Certificate
Wherever issued by a SAMSA officer, there is a prescribed way of certifying the buoyancy. (Attached as Annex 5).
Note that the example would have to be modified for different situations, for example where the vessel is an inflatable, or has watertight subdivision (i.e. has ‘one compartment’ flooding capability), or has complied with the passenger vessel buoyancy and stability requirements. But the layout and relevant sections must be kept intact.
Where SAMSA officers or Authorised Agency safety officers and inspectors are faced with alternative documentation produced by other parties, the following principles must be applied to all forms of buoyancy certificate.
It must be clear who the issuer is, for instance the boat builder, private surveyor, safety officer, owner etc.
The vessel itself must be clearly identified by photograph, serial number or similar.
The basic dimensions and build details of the vessel must be included to aid the reader with not only identifying the vessel but also making it possible to detect any major alterations which may affect the validity of the certificate.
The quantity, type and distribution of buoyancy must be described in detail.
The net weight (light weight) of the vessel must be noted, as this is the best method of monitoring absorbency or water retention of either foam or bottles.
The certificate must attest to compliance with the requirements of regulation 6 and Annex 1 or conversely state exactly what is in fact being certified.
Any limitations, conclusions or comments must be clearly noted, especially when bottles are used as they have a limited lifespan."
See:
http://www.samsa.org.za/content/buoyancy-small-vessels
http://www.africanangler.com/sb_article.asp?id=62
