We fished Jozini last weekend on Tony Talbots charter, we also stayed at his camp which was very nice as well, we caught Tigers up to 3kgs, attached is a photo of my son and a 3 kg tiger.
the weather was cold, wet and very windy, dusting 25-30 knots. We had one take on live bait, which by the way was very scarce. Everything else was caught on sardine fillets. We fished in 6m of water tied to a tree, can't tell you where because Tony might be using this spot next weekend. One of Tony's comments was that boaters tend to move around to much, if nothing has happened at a spot, after motoring in, tying to a tree or anchoring it sometimes takes a while for a spot to settle down. he does say though that he's caught plenty of tigers up to 6kg's in the estuary and river to warrant not going onto the dam. One spot we did get a lot of bites at is up the river in the bay where the big pleasure boats go in, anchor in the reeds and fish towards the centre of the bay, this would apply I guess to a lot of the bays on the eastern side.
We fished using 4/0 bass worm hooks ( chemically sharpened) un-weighted allowing the bait to drift about. Cast out from the boat and let the bait drift.
Choice of reel should be a bait runner, Tony reckons that since he changed to bait runners the hook up rate has definitely increased, I used a bait caster but on free spool under my thumb which worked ok, centerpins would also work, but you need to be in contact with the rod all the time, we found initially we were striking to early, another thing keep the rod tip down when you get the fish close to the boat. Line class I had 2 break ups using 12 lb so 17 lb main line should be use with a long fluoro carbon leader of say 20 lb, good luck next week, tight lines, screaming reels and all that
Another thing the local ice machine was broken, hopefully it will be fixed by next weekend
