Jet Ski Buoyancy specs....
jagot
As a Small Craft surveyor I'm often requested to verify certain specs (buoyancy, dry weights, etc.) for jet skis. Only a few manufacturers buoyancy specs are available. I seriously need Polaris and Tiger Shark specs in particular, as these guys need to get legal and back on the water. Any help out there?
BigVan
Hi
I can give you the info that is on my SeadooGTI 4-Tec buoyancy certificate. If I am not wrong will it be for Polaris.
Dimension: Lenght-322cm, Breadth- 125 cm, Depth- gunale to keel-43 cm
Built in buoyancy: under vessel filled with foam Volume-2.22 cubic meters
Foam type: polypropylene conforms ISO13590 an US CoatsGuard31CFR183.114
Wet weight409.1 kg, Dry weight-339 kg Carry weight 272.7 kg
Vessel ability to survive flooding: Vessel passed flooding according ISO 13590 and US CoastGuard part31 CFR 183.
This is quite a lot of nonsense but hope it helps you.
