I've had a few request on how I rig a circle hook
Dave Batista
FLUKE wrote:
Dave Batista wrote:
FLUKE wrote:
That steel to leader is a notoriously weak connection and has been the break in many a heart break moment.
Alton If you were to use a 1.5m piece of 120lb blood wire lets say and join it to a 1.5mm leader what method of connecting your leader to steal would you use?Swivel or knot? and why?
We're getting off topic now but I'd use a swivel because steel is hard so it never pulls up tight so the knot never sits as neatly as with nylon and is also prone to slip. Both the problems result in a dramatixally reduced knot strength. With a swivel you get a good connection because you aren't trying to join soft nylon to steel wire.
If you insist on not using a swivel then use back to back fig8 or an albright.
Thanks, will just have to see what sized power swivel will fit through the coils of the slide,if a 1/0 can then I'll be happy.
FLUKE
Any decent slide can get over a 1/0 power swivel. Your problem is that the Fig 8 tag end of the 1,5mm leader points back up the line. So when the slide gets there it can get caught on the tag end. You have the same problem when joining with back to back Fig 8 knots except then the steel tag end points up the line. An albright is the best for the non-return clip to go over if you leave the tag end quite long and when I tried this(bite trace) I used the Albright method. I however found you could not pull the nylon tag end of the Albright tight enough by hand so it would slip and/or pull an inconsistent tension on the coils. It became very apparent to me why there were so many failures at the albright when a big shark rolled on the leader so I lengthened my slide trace and took my leader all the way to the stopper ring with a thimble and that is the way I fish.
We are targeting big sharks with big teeth in rocky terrain. You can do whatever you want and you will still loose sharks. I will rather risk a bite off on the pick up where the shark will still bite again rather than loose it after an hour when it rolls on my leader and what might have been the only shark of the day is lost because of extra connections in my line.
Have never and will never add that bite piece into the leader.
Seen more connections go after a long fight than bite off's
PowerCaster
FLUKE wrote:
Fishing Meister wrote:
hey Fluke Great Post. I assume the bottom loop on the wire is obviously for clipping the sinker when casting.
That being said, Is there a reason u make it the same length as the bait and not slightly longer ?
Mainly neatness and also to keep the sinker closer to the bait. The closer the bait is to the sinker the better it casts.
Having said that if I get a pull on a bait and re-use it or change bait types etc there are times that the loop may be 1,2 or even 3cm below the bait. In this instance I just use it like that and it still works.
And yes the loop is to clip the sinker on I just didn't think to take a pic with a sinker clipped on. I still have that rigged in the freezer so maybe I must take a pic and post it.
Apic perhaps of the sinker
boepens
I wiLl only use that extra steel on my leader when there r small rags around cause of how they bite and make it min 1.5m long. Use an albright knot.
As for circle throwbaits I have my own style of rigging. The bait won't come off and is also nicely centered on the clip. I use a piece of normal .7mm fencing wire. This is for head throwbaits. Ill bend a nice section in the wire and push the straight end through the lips of the head bait till it comes out the middle of the end , then push ur circle through the lips of the head and the loop and secure as normal with a cable tie. Then just bend a clip on the other end close to the bait and clip and throw.
Simple and cheap.
The foam represents a head. Wire inserted
boepens
The ready to throw bait.
Hook through lips and loop and cable tied in place.
Clipping hook made and clipped for casting
rautie001
Just a quick question guys...
Does your sinker easily unclip after your bait has hit the water. I see you make a loop rather than a usual "V-bend" (if one can call it that. Any reasons why you make a loop rather than the V?
FLUKE
I like to use thin wire as it allows the wire to run over the outside of the bait which is necessary as I predominantly use head baits and like to rig them while still frozen. The thin wire is however not strong enough to just put a V shaped bend in it as it would just bend open again. I therefore use a loop.
It unclips perfectly! I have not had a single issue.
