Iron candies
duckbill
Hi
I bought these a few years ago and forgot all about them. I think they would work great for leeries and elf in rivers.
I'm thinking that the orange one will work in dirty water, while the blue one will be better for clear/clean water.
What are your thoughts?
Thanks,
D
Rochee
Ive caught a Garrick on the pink one from the shore and as HH said below, lots of Shad. You use a slower retrieve for them which makes them more appealing to Shad.
willo
If I'm not mistaken all those bullets are the "glow" variety and will work in all conditions. I have had every colour and still do have most of them , but only ever really use the glow units as they tend to get a lot more hits .
My go to is the green glow which has accounted for multiple species over the yrs .
I have had a lot of success on the iron candy range , they don't like the rocks and I paint mine with resin before they get used . Just gives them a extra layer of protection and it does help a lot .
If you not fishing in rough country try pausing them for a few seconds and give them a little jig , you can add a skirt to the nose as well on some assist hooks .
I have caught a lot of fishing using that method.
Before you use them , just give the hook a solid pull and check the split ring .... I change all of mine straight away as I have lost to many fish to split ring failure .
Good luck
duckbill
Thanks for the tip regarding painting them with resin.
I generally fish rivers where chances of getting snagged or ruining the paint job of the lures are slim.
I replaced the original split rings with stronger ones immediately after purchasing them.
I've also fished the 42g couta version at night, hoping for a nice elf. So far I have not had any success with this approach.
