Importance of using a baitrunner
JPG
Hi guys,
Does it really make that much of a difference using a Baitrunner for conventional carp fishing? I'm not referring to serious competition angling. Just going out there and having fun.
I almost at the point where I just want to sell my rod and reel and start over...
fishy_fishy
Hi JPG
Baitrunner is a nice to have. For conventional carp fishing you can use any reel you wish within reason. The convenience of the baitrunner is that it has a lever that allows you to easily put the reel in 'free spool' mode. This has benefit especially in specimen angling as when the the carp spits out the hair and gets hooked it runs frantically. Because the baitcaster is in freespool mode the fish 'runs' with little of no resistance. The same can be achieved with a conventional reel with a decent drag system. Another cool feature of a baitrunner is that when you pick up to reel the rod from freespool mode it automatically engages the spool and the traditional drag kicks in. Like i said it is a nice to have. Many manufacturers are making baitrunners these days, not just shimanos. (Okuma, Jackal, etc.)
fishy_fishy
The attached document will be beneficial. Its from one of the Sealiners on the Forum.
Good luck
:f1shy
  • Things I wish I knew before I started_V1_Final_03.01.2012.pdf
JPG
That is BY FAR the most informative piece of literature I have seen on the internet.
Absolutely awesome. thank you for sharing it
IWyk
Makes things easier but definitely not essential. If using a reel with a quick adjustable drag(eg. Ultegra) without a bait runner, just set the drag with the right amount of tension for the fish to run with it.
Once you get a pick up lift the rod, you can apply slight pressure to the spool with your left hand if needed(this comes automatically after you have done it a few times) and then you can adjust the drag with your right hand.
The drag on the Ultegra is very quickly adjusting so you only need to turn the drag adjustment a small way to get the right tension.
JPG
Fair enough, but at 2k a rail its not something that I can consider to get a pair of...
All im looking for is a nice pair of rods and reels
deisel
I think its also got a lot to do your preference. Ive fished bait runners but prefer a normal reel with drag on the spool. Like the standard emcasts ect
