Hey Morbus, Pic is not in Cape Town, it's on the South Coast.
The amount of "life" you give to the lure will depend on the water you're fishing. Blacktail, Wildeperd, Hottentot and even small Musselcracker are the type of species you'll be targetting and these guys all like a bit of white working water.
I hardly ever fish a 2" camo worm on a heavier setup than 1/8oz. When you throw 1/8oz in white water it's gonna move so you basically just have to "steer" it to the exact spot where you feel most comfident... I found the less weight I put on, the less I get stuck.
My most succesful way to fish for blacktail (You pick up other species in the process) is a near weightless setup in rock gullies. 1/16oz ball sinker on your 14lb nylon main line (remember there's sharp rocks and braid is expensive), power swivel, 55cm 17lb fluoro to a 1/0 hook with the camo worm along the shaft of the hook with the tip standing proud. You won't get much distance with the weight you're casting, but if you choose your gully well there will be a current pulling out at least half the time. You won't believe how close to your feet you can actually catch fish.
Regarding the sauce, it will benefit you to buy one of those tubs and put all your soft plastics in it. It stores them very well and you can recharge you plastic every 7th cast or so... Especially with small reef species in the white water, they can't see sh!t down there, but they rely on smell to find food and steer clear of predators. They follow that food smell from the sauce and the moment they register that "worm" shape in front of their faces, VAS!
It helps to find a spot with black mussel on the water line, take a rock the size of a coffee mug, climb down to the mussels (Be careful) and smash a few at the water line. This releases a chum cloud, but more important, mussel worms (looks a lot like camo worm) live under the mussels and with the smell of disturbed musselbed in the water a mussel worm would be a very likely food source in the water at that time so any fish won't think twice about eating your camo worm.
