I have simplified this kick boat to keep the cost
cranky
I have simplified this kick boat to keep the cost down and to try reduce the weight slightly
stripped on the workbench for easy transportation in a small vehicle
stripped with pontoons attached and all it takes is two bolts to assemble...but you can fit more kick boats into one vehicle...the bonus is the pontoons are pumped up and attached to the frame already...you just slide the frame together...push the 2 bolts in off you go...this way you can pump your pontoons up at home less time wasted at the dam.
