hydraulic steering fluid
nicsavage
Good Day Gents. I have a Admiral Hydraulic steering system fitted to my 5.1m Stingray Rib. What oil is the correct oil to use in these systems? Need to top mine up. Thanks Guys.
Aqua Azul
I get this on the net
Admiral manual:2) Have enough clean oil (Only HYDRIVE ULTRA-15)
This is an Aussie oil, A hydraulic oil as follow will work:
There is no substitute fluid you can use without damaging the seals. The manual says use only Ultra 15 hydraulic oil. Use only 15 weight hydraulic fluid.
