howto sard shad bait
thornza1
Hey guys,
whats the best bait presentation for shad(elf) when all I've got is frozen sards? I've tried to make a nice bait but the sard is so sloppy and messy that it never turns out well. I'm using a shad trace (red cork float, metal trace with what looks to be a 4/0 longhshank hook).
Just wondering how everyone else does it?
shot!
thornza
SharkBait
Hi Thornza
I like to start off with a whole sardine , pinned threw the eye and hook then inserted on the side of the sard close to the tail with the hook standing proud . Even when your sards are frozen solid this bait looks good .
Mouse
Hi
When the sard is floppy and belly coming out, use a peace of the blue plastic that the sards come in to wrap around the belly not the whole sard but just the belly. Helps to keep your bait firm for shad
Jude
Hi Thornza1
Well as everyone has said thru the eye and hook thru the tail absolutely 100% correct. If ur Sards are frozen just cut thru a quarter of the way thru sard from tail to head push ur hook up from under of sard and lay the trace wire in sard and wrap wid gohst cotton jus make sure ur bait is strait n tru and u will def get a pic up.. Shud you get urself a size shad and ur sards run out fillet the shad n use it as it is fresh n does not go pap ...
Def-e-nition
 I dOn't have a phodie Ready made and voila - all I have on my pc are of some ideas that i used on half sards . Because you want it to last a bit longer in the water I' used a bit of chokka on the bloody end , wrapped it up , and used 2 hooks .
Nothing special , but I have found that if the hook Is proud , the hook-ups occur more Often   .
thornza1
Hey cool guys thanks for the info!! gonna try some of these ideas out in the next couple of days.
Def-e-nition - shot for the photo. Are your hooks pinned in or just pushed through the sard? I find if I just push the hook through the defrosted sard then it tends to wobble about and gets flattened against the bait instead of standing proud.
later!
Def-e-nition
Not Pinned dude .The bottom Of the bait will basically Keep the hook Facing the right way round - it's standing or hangin so proud , even if It Turns around it's standing so proud it's gonna hook up in any case .
Yea , sloppy pilchards is a Bugger to work with . I recently started using the method someone posted for using with Mullets .Not as effective , but I macguyver it to work almost the same way with Pilchards . Through the mouth , just behind the gills , and then through the stert . hook proud . Might be necessary to toothpick it , but if there's one thing I've learnt , out of all the mistakes I make- it's not having the hook proud , or , in the case of elf - not having the hook facing the right Way , in the right Place . Elf like Taking fish from behind ( . . . . . ) so naturally putting the hook there would make the most the most sense .
The sards we get down here are sometimes a little too big to cast whole . Even then , although I am guilty of not doing it - I would suspect that having the hook face forwards coming out the tail side might produce better results .( I have and still do , use the tail half , and have the hook sticking out proud from the thicker bit , away from the tail end ) head I always always have the hook facing towrd the mouth, as the softer Flesh side would obviously be the nice part for them to grab.
Hooking Whole Sard hook coming out of the tail end works as well for Leeries . I read somehwere they smack the bait , stun it , then they turn the bait around to swallow it tail end first . On Dad .Well , at least , thats the theory .
Jude
If you using half a sard always cut bait in an angle from halfway in this  angle \ like a 45 deg make sure ur hook is proud and to prevent it from turnin and pullin into the bait to much u can toothpick it as Def mentioned also make sure u wrap cotton around hook and turn on bait a couple times but not too much cotton. Cleanin the cotton of becomes irritatin n time consumin. You can also purcahse the shad needles that u can just poke straight through the tail exitin at head of bait.
Def-e-nition
Jude - I got me one of dem tings - do you cut the hook Off Each time , thread the Sard up , then re-tie the hook after each Cast ?
Never Really bothered to learn how exactly To use the thing man ... !
WHo's got a diagram now ....
 I have a straight needle- are you Talking asbout the shad needle with the Treble connected to the end ?
Jude
style="BACKGROUND-COLOR: #f8f8f8"
style="BACKGROUND-COLOR: #f8f8f8"Hey bud hav not used extensively, but i used to remove treble as u end up hookin urself more than the fish... The point wid the eyelit push from tail exit head attached to snap swivel on the end of the float. i prefer using conventional trace with single hook rangin from 4/o to 6/o and steel wire which is really firm as it assist in keepin bait straight aswell.
tauruck
Homie wrote:
Hi Thornza,
Use the whole sard, double hook, 1 through the lips, the other at the tail.
I used that trace in Mtwalume when I first started just to keep the Sard from sliding down. My rod bent double and we all thought I was into a big one. Turns out I had a double hook up. Some of the locals weren't happy.
