how to bait a hook for Shad
Dr.Cheese
Hwzt guys
I wonder if someone can help me, im going down to the south coast this weekend and i want to know the easiest way to hook a sardine for Shad?
I will only be using sardines and a size 5/0 hook.
I am still a novice so maybe a smallish(half sardine) or fillet sardine would be best.
all the help or pics would be appreciated.
kind regards
JVW
I see no replies.Well  i am jo'burg oukie-but here goes.As long as you have a bait in the water,you stand a chance.Cut off the tail fin and halfway diagonionally-split the piece-rap around the long shank and tie with latex.Remember to always leave the hook proud.If your trace is bitten off - use steel trace(shad-rapid biting).Try to always keep your bait "streamlined".
HOW'S THAT FOR A BRAKPAN OUKIE WITH A COUPLE OF WHISKEYS DOWN.
Oh, and keep the rod in hand-those elfies are quick.
CHEERS AND WELCOME
Jannie.
:welcomesea::welcomesea::wfish:wfish
Doogle
What's up Doc
I find I do better fishing for Shad using Pike or Chokka. The Pike is slightly tougher than Sardine so will stand up to one or two knocks from a hungry Shad. If they not taking on the fish bait try casting Chokka cut in strips and woven onto hook.
This is what works for me so good luck.
:fst:
The Shad/elf are true to their Australian name ie. Tailor. They attack their prey by biting the tail and thereby rendering them inable to swim
Then they go about eating the fish.
Whether using whole sard or pieces the hook must come out at the tail as they hit the tail first.
I like to fish a whole anchovy or Sard on light tackle with an inline sinker on the rig, cast it out to the feeding Shad, let it sink and then retrieve slowly when the machine gun bite happens hit home and pull, don't give slack or the shad is off
I simply thread a long shank 6/0 from Bandit through the eye of the sard, pull it through and push the hookpoint through the side at the base of the tail. Tie the fish on and then make sure to tie it tight on the head and lips to prevent it pulling down and this keeps the bait straight and stops it spinning in the water
First bit is on the tail just where the hook is and he's on. when the shad are around every sard is a Shad - Guaranteed.
Dr.Cheese
thanks for the tips guys, i will try that this weekend and hopefully all goes well.
will let you know how it goes.
