How do i!!!
TJC777
Hi all
Silly question , will maybe.
I will be fishing at between 180 - 200 meters , i want to make a feeding bed but cant leave anything in the water to mark where it will be.
How do i make sure i land in the same spot ?
Any suggestions or ideas would be great!
Thanks for all the help!
J
At that distance I will assume you are dropping your baits, after you drop the first time take a small piece of tape and stick it on your line, then when you go out again just watch for the tape coming off the spool (or get some one else to if you are rowing) and you will drop at the same distance every time.
Tjooona
Yep. you could also clip the line into the spool (If your reel has this clip on the spool) works great when fishing short distances and when distance is a factor.
Spod
Firstly,
Clipping the rod works well, find a referance on the horizon (opp bank)for your left right co-ordinate. just be carefull you dont go too quickly near the drop zone as there wont be any give from the clipped line.
Secondly,
Remember, you cant clip your rods you using to fish and leave them on the pod clipped, as when the fish takes your bait, he's gonna take your rod aswell or snap your line.
Thirdly,
To transfere your distance to your fishing lines, try these methods:
1)Walk your rod lines out on the bank against your feed rod line,(which you clipped) Then, either as J says tape it with a small piece of insulation tape or use a black veldtip pen and mark about 500mm of line near the reel.(you may need to reink it every now and then as it does fade)
2)Or you could buy a line meter, they not expensive, about R100 and clip it onto your feeder rod, read the lenght after you drop your feed and transfer it to your rods you using to fish with and drop at the reading you got. then mark each of the lines as said above.
Using these methods, you need help on the bank, sothat you reach the same spot everytime provided you work off some referance points on the horizon,opp bank.(eg.left right)
3)Or if you have the money, a cheap gps with way point facillities would work well too.
Hope this helped you
