On sunday I get to the rocks, open my cooler box & see that the foam has come off & is stuck inside the cooler box. Used my knife to get it out, eeeish.
Do I use normal glue / silicon to stick it back on ?
Or is there something else i can use ?
I used contact adhesive for the best results. Silicone doesn't work well at all. I tried it before. I did mine about 2 years ago and it still seems to be holding fine!
I agree with the contact glue. I did the same to mine, but it came loose after a few trips.
I was told to use a sealer, waterproof contact, for the edges. This was done and it still holds fine. Thanx Subaruseun for the tip and waterproof contact.
