HELP NEEDED ON METAL SPOON
Ben REINERS
Hi to everyone out there ,
I had recently (ab 6-10months ago) seen a fishing spoon mainly used from shore ,rivers and or estuaries in a fishing mag. I paged all my mags , with no luck and its so frustrating cause I know its there , just cant find it.
A short description - its a solid round bar , +- 10-12mm in diameter ,with a very thin hole through the middle. The metalis either brass or copper with a thick solid iwall.
The whole spoon in length could be +- 5 to 8 cm. both ends of the spoon is flattened each on the opposite side.
Small holes are drilled on the edge of the flattened sides where split rings are fitted for the hooks and swivel respectively.
Could someone tell me if he has seen this lure before with details as to where to obtain it or is there someone out there that could make such a lure ?
Festive regards Ben
Guppigetta
Hi Ben, are you not talking about the stainless steel spoon that is made of a straight bit of s/s rod with the ends cut off at opposing angles? I made some out of 10 mm s/s rod. They are very easy to make,all you need is some rod and a hacksaw. Cut the rod at an angle of about 25 - 30 degrees, then about 30 - 50 mm further cut another angle in the same direction as the first. You now drill a hole at each end and polish the spoon.Fit each end with a split ring and you hook and swivel. You can make these any size as you wish.
Ben REINERS
Hi Guppigetta,
Yip u quite right - one added issue , it has a medium to thin hole right through.  The hole allows water through thus making bubbles at the rear of the spoon. Its just an added attraction for the fish you target.
I suppose one can make them yrself , but whats makes it worse i saw one being advertised in a fishing mag but cant find it.
Guppigetta
Hi Ben, If you can't find the tubing you are talking about and you have access to a metal turning lathe you can drill the hole through the s/s rod yourself. This will give you the advantage of deciding the size of the hole you want.
jb2
Ben REINERS wrote:
Hi Guppigetta,
H Ben
The type that you describe is made by Halco and is called the "streaker". Kingfisher imorted a very good copy a while back. The photo below is from the Halco site.
213
Ben REINERS
Hi Guppigetta & JB2,
Thks again for the advice. Yip G u are right , I actualy love my own home made lures and will try that, but was a bit in a hurry to get one for a trip , but to late. Now JB2 came to the rescue.
Now i will buy 2 or so and start making my own fromm solid brass and stainless.
Thks again u guys - I struck gold once again.
Rgds BEN
Geezer52
Bought one a while back at Midas Motor parts store. Dont know if they still stock them though. Think it was less than R20 bucks. Casts like a rocket and can be retrieved fast as well. Looks the same as the Halco.
Ben REINERS
Hey GEEZER ,
Thks for the info  - got a mate that used to work at AKALS-MIDAS DBN. Will call him to see if he can get.
Thks & regards Ben.
