OOOPS SORRY I POSTED IN THE WRONG SECTION.Hey guys, I found this article. Lets hope our trip will be fine,. BTW any idea hows the water, and whats coming out in tugela. Heard teh river was in flood a week ago
Stay away from the beach from 18-20 March.
Earth, sun and moon get in line
March 12 2007 at 06:42AM
By Bronwyn Gerretsen
Scientists are closely monitoring KwaZulu-Natal's tides in anticipation
of the moon, the sun and the Earth's alignment on March 18, which will
see the greatest gravitational pull on the earth in about 18 years.
But while this alignment could result in dramatic high tides and has
people living along the coast bracing themselves for tsunami-like sea
conditions, an expert has said that unless these tides coincide with a
storm at sea, the effect of the gravitational pull could be minimal.
The lunar eclipse, which took place at the weekend is an indication that
the three bodies are moving into line with the Earth obscuring the sun
and casting a shadow on the moon.
'The gravitational pull of the moon, counteracting each body's force on
the Earth' Andrew Mather, the eThekwini Municipality's Project Executive
for Coastal Policy, explained that the surface of the Earth, especially
its water, is influenced by other bodies in the solar system,
particularly the sun and the moon.
"While the moon is spinning around the Earth, the Earth is revolving
around the sun in turn and, because the moon does not orbit the Earth in
a straight plane, the Earth, the moon and the sun are not always in
alignment," he said.
The three bodies only align horizontally every 18.61 years and, when
this occurs, the gravitational pull on the earth is at its maximum.
Mather explained that the moon orbits the Earth on a tilting axis,
moving up and down, almost with a see-saw effect, and the gravitational
pull of the sun usually opposes the gravitational pull of the moon,
counteracting each body's force on the Earth.
This accounts for the "normal" tide levels. However, when the forces of
both bodies are pulling on the Earth in the same direction, the highest
variation in the tides occurs.
Although this alignment is due to take place on March 18, Mather said
the delayed response of the gravitational pull would mean that
KwaZulu-Natal's tides would only be affected on March 20 at
approximately 4.30am.
Mather's tide predictions showed that the high tide would be
approximately 2.19m at this time, an increase of about 10 percent on the
usual height. The high tides experienced in March and October last year
reached a maximum of 2.18m and 2.16m respectively.
However, Mather cautioned that people need not be too concerned as this
increase would not necessarily have a huge effect on the waves and would
hardly be noticeable when looking at them.
Areas that would be mostly affected would be La Lucia, the Umhlanga
beachfront, St Michaels and possibly the Durban beachfront, he said.
This article was originally published on page 6 of Pretoria News on
March 11, 2007
March 11, 2007
