Heavy rod suitable for low-swing penduum
mnyamane
I broke an assassin heavy hmg during practice, it broke while doing a back-cast. Both butt and mid sections broke at the join. I need a heavy thick-walled rod to perform both back-cast and low-swing pendulum (without running a risk of being hit by the 8oz sinker on the head when the rod breaks). I've read reviews of the sensation rugged, impressive. None the less, I need a rod which is suitable for the above-mentioned casting styles.
NB! Similar topics had been covered in some of the threads, but not for the mentioned casting styles.
I'd appreciate and welcome your advice.
kitefisher
Mnyamane,an alternative to the ones mentioned already would be the old school Purglas 400,but unfortunately I would recommend the one-piece only.This could or could not be a transport hassle to you. Stroke /5,/6 or /7 should handle your requirements without bullying someone of a smaller stature.(as myself).
AFAW may also be an option.;)
mnyamane
Thanks Enigma and Kitefisher for your responses. A one-piece rod will definitely be a transport challenge as much as I wouldn't want to import any of the rods; expensive. Other than a one-piece purglass will a sensation rugged do the trick, Enigma?
scorpion
Waft krugersdorp have so.e century made blanks in stock. Plan b order 2 century rods a t1000 for you and t800 for me.it is Christmas after all.
kitefisher
Mnyamane,perhaps you should ask Purglas to build you one with the old material(not sure now if it is 24 ton or whatever,never been too much into the technical stuff.I am sure they can build you a decent two-piece which will be the same transport hassle as a Century or Zziplex two-piece.Perhaps request additional support at the spigot-joint.
I am certainly no rod-expert(although I own a few), but I know that European style pendulum's ,Low /Cross-tip or High, are not very friendly towards HMG-rods.However I must emphasise that X-Cast variants are more friendly than traditional High-swing pendulums which can place more rod-torque stress on a rod when ill-timed.
Sincerely hope you find what you are looking for.You are in a difficult scenario,because you cannot exactly test-cast a mate's rod.btw,I am very aware of your casting proficiency.Keep it going.
Basically take an 8oz rod to do the cast you want to do with the 5-6oz or a 10oz rod to do the 8oz in casting style you want to do.
flippy
zziplex trc :shock:
eliminators as mentioned also niice
afaw tournament
good luck sipho.. old school proper back casters was no good for fishing in the sense that it was so thick and heavy only used for casting this power stroke and put in pension pipe and reel in line or fish but not for fishing while day.. try go non hmg lol
also sure enigma can build a thick walled rod for this purpose thats also fishing friendly.
Blue Marlin also do a 2 Piece blank built similar to Zippy/Century style,
100-50 Super Slim is slower style material and this past weekend we had Hennie Papenfuss casting an 8oz sinker and small dummy bait over 200m and a 7oz with yellowtail head over 160m so it can definitely take the punch
It is not full HMG and takes some serious punishment.
I have a few customers in Indonesia and Australia who have the 80-100 and 100-100 and use them for Field Casting tournaments. Initially we had a few issues with ferrules breaking but since introducing new Ferrules in October 2014.
Personally I have taken a 100-100 and cut it in half and built myself a spiggot joint system with a serious wall thickness and my 2 piece 13' is an awesome casting tool.
kitefisher
Hiya Craig, that is some brilliant casting.Would that be a multipiece rod (3-piece).It would be very interesting to know which reel and line set-up was used.
Like you,I am also more comfortable with a slightly shorter set-up.
p.s Sorry for the hi-jack Sipho,but I am sure the info will be valuable to you as well.
mnyamane
Gentlemen thanks for your input. I PMed Enigma about the rod. Kitefisher I have shattered a few rods now I need a solid blank (though, I still have the TTR 😀).
kitefisher
I have seen a couple of back-casts made on a TTR,Not with an 8oz though,(although not impossible).However,you are in good hands now,and I am sure you will get the right rod for your application.
Cheers ;)
100-50-420 with Fuji Low Rider setup, Ultegra 14000 30lbs Braid with 100lbs Braid Leader.
He also did a number of same casts with a 3 piece Shimano that we modified with 6oz and strip baits,measured at 207m but with 15lbs Braid.
OTG and South African Surf Cast
