HAZARDOUS MATERIALS INFORMATlON BULLETIN
neilze
[align=center]HAZARDOUS MATERIALS INFORMATlON BULLETIN
MATERIAL SAFETY DATA SHEET
WOMEN - A CHEMICAL ANALYSlS
[/align]
ELEMENT :
Woman
SYMBOL :
Wo
DISCOVERER :
Adam
ATOMIC MASS :
Accepted at 53.6kg, but known to vary from 40 - 200kg
OCCURRENCES :
Common element, found in various areas in huge quantities
PHYSICAL PROPERTIES :
1.   Surface usually covered with painted film.
2.   Boils at nothing, freezes without any known reason.
3.   Melts if given special treatment.
4.   Bitter if incorrectly used.
5.   Found in various states ranging from virgin metal to common ore.
6.   Yields if pressure applied to correct places.
CHEMlCAL PROPERTIES :
1.   Has great affinity for gold, silver and range of precious stones.
2.   Absorbs great quantities of expensive substances.
3.   May explode spontaneously without prior warning and for no known reason.
4.   Insoluble in liquids but activity increases greatly by saturation in alcohol.
5.   Most powerful money reducing agent known to man.
COMMON USES :
1.   Highly ornamental, especially in sports cars.
2.   Can be a great aid to relaxation.
3.   Very effective cleaning agent.
TESTS :
1.   Pure specimen turns rosy pink when discovered in its natural state.
2.   Turns green when placed beside a better specimen.
HAZARDS :
1.   Highly dangerous except in experienced hands.
2.   Illegal to possess more than one, although several can be maintained
      at different locations as long as specimens do not come into contact
      with each other.
SAFETY & HANDLING
If specimen heats up excessively or becomes ice cold (as can happen), normalizing of the specimen’s temperature can be done by neutralizing with red roses and / or expensive chocolates and / or expensive dinner. If this does not adequately stabilize the specimen, more intense actions may be required. Copious amounts of credit card spending will normally result in a fully stabilized specimen within hours.
If there are indications that the specimen may explode imminently, it is best to vacate the site immediately and avoid the inevitable dissipation of high velocity shrapnel. It is recommended to not return to the site until the specimen has either fully exploded or returned to ambient temperature again. Generally if the specimen has exploded, the safety precautions mentioned in the previous paragraph will need to be applied to fully stabilize the specimen again.
