Grunter on top water
Gareth88
Hi guys,
I've just bought a z killer top water lure to try and target grunter. It says on the box to keep the rod tip up and retrieve using the walk to the action. I can't seem to get any action on it at all in the surface. It just sort of drags along the surface. When I keep the rod top down and give a few jerk during the retrieve it seems to have the side to side action but only under the surface.
Is there any special technique to the walk the dog action on the surface that I need to do? Any help would be hugely appreciated.
Many thanks
Splasher
Take into account the speed of the current of the water as this plus the speed you are retrieving at will pull the lure out of it sweet spot.
The speed has to be right to get the lure to swim properly.
die spook
Naand
Ek sukkel net so om die Z Killer op die oppervlak te laat loop. Ek gebruik hom maar sub surface.
Suidkaap se leeries vind die wit 9cm enetjie onweerstaanbaar. Op twee geleenthede by verskillende riviere daar het hulle sekondes nadat die Z Killer in die water geland het hom gegryp. Die een wat ek wel kon land was naby 60cm.
Ek wil graag Decoy inline hoeke op my Z Killers sit. Sal 1/0 op die 9cm en 2/0 op die 10.5cm groot genoeg wees?
Is daar dalk enige planne om Z Killer poppers in dieselle kleure as die Z Killer stickbaits uit te bring? Sal nogal nice wees.
Spook
Jacquesdw
The ZKiller is not the easiest lure to WTD with. If you have never WTD before I suggest getting a topwater pencil that sits vertically at rest, ie all the weight in the back of the lure. Pretty much any lure that sits like this is very easy to WTD. Strike Pro Thai Sticks, Rapala Skitter walks etc.
Then move on to the ZKillers. The reason they work so well is that they sit horizontally in the water and low down, almost sub surface. The horizontal position looks more natural at rest and the low water position means it moves more water when walking so sends out more vibrations. Also better visibility when the wind is blowing which is pretty much all the time at the sea.
Watch some YouTube vids to see how it is done. Remember to to give the line slack after the jerk so the lure has space to slide out.
Practise in a dam first with no wind. A belly in the line caused by current, wind, waves will make it harder. When you are using it in an estuary, the above factors will vary during each cast so your retrieve will have to vary. Thus you must be able to see the lure at all times otherwise you don't know if it is working properly.
Pretty soon you will have it down pat. It is an important retrieve to know as you use the same one for sub surface pencils, like Storm Fluttersticks, where you can't see the lure. Good for jerkbaits too, like small Rapala XRaps.
Your rod is also important, It must not be too stiff. Some of the rods available in SA are using old type blanks which are like poker cues. As you give the rod a slight jerk, the rod must "load up" and then release its power in an even power curve. Otherwise the lure will just barge its way through the water directly towards you.
I have used rods up 9'6 for ZClaws, which are much more difficult to WTD (see pic below) but gave that up as my wrist could not hold up after some hours. Favourite rod lenght in SA is now 8'9 rated up to 35g. Here in Singapore I use a 7' Majorcraft Corzza (10-42g) with a Lew's Inshore BB2 baitcaster. Use a 30pd FC leader because of barracuda and barramundi's teeth. Walks perfectly even with a heavier clip and FC leader.
Gareth88
Thanks for all the advice and tips.
I'll try and watch a bit of footage on YouTube and keep practicing. At the moment it's a frustrating exercise, but I'm sure it will be a sense of achievement when I et the first fish.
Spook, I had better hook ups with the bigger inline singles, 4/0 for the smaller lures and 5/0 to 7/0 for the bigger ones.. Even with the smaller shad, leeries and katonkel the 4/0 and 5/0 stuck when the fish hit the lure from the side and caught the scissor of the mouth when the fish inhaled it, the 1/0 and 2/0 inlines would catch on every 4th or 5th hit only when hooking from the outside the mouth and the same when lure was inhaled.
Jacques, is that a barramundi and a grunter together in that shot!? Tell us more mate! :)
Gareth, I find the walk the dog easier when my rod is at almost 90degrees to the line, you must get the rhythm, flick, crank up slack, flick crank, flick crank...when you time the flick, pause and crank right in rhythm the lure rolls and darts in the walk the dog, it is the way the fish want it in the estauries.. When I'm out of rhythm mates will be catching around me, leerie, grunter, shads and me nothing, till I get into it again, and I start catching..if there are fish there haha..
Jacquesdw
LOL Dr hh!! That's a skinny cob!
That 90 degree angle is so important. Which means that you must shift the rod angle as the current moves the lure during the retrieve. You will also find you are better on one side than the other. You can keep the rod tip up but with the wind in the Cape it is better to keep it low to the water while occasionally giving the rod a big flick up to keep the line relatively straight (mending the line as the fly fishermen say)
Haha, now I see :) Ja his folded top fin and head/mouth had me guessing.. On the walk the dog, I also find it easier with rodtip down and standing with rod to the right, and I'm right handed..if that helps
