JRFisherman wrote:
Forum. Question here about grapnel sinker. I am making my own grapnel sinkers. The stem eye or longtail eye you set in mould before pouring the lead. Is 1.5mm wire a good diameter? Is 1.5mm wire a strong enough diameter to where the stem eye won't open up fighting a big fish from the beach? or do I need to go up in size for stem eye?
Hi JRFisherman,
1.5mm is more than strong enough. I use a spring steel stainless wire of 1.6mm. That is what I get get at the time. Once you have casted your sinker and bait, not much pressure on the wires except in very strong current. I have fished an 8 ounce grapnel sinker with 1.6mm wire and a yellowtail head (1.2kg's) in a very strong current and the sinker held very well. This was done when sliding the bait with a non-return clip. You will be well served with your 1.5mm wire. I have decided not to use stainless steel wire anymore as when sliding the bait, the sinker will dig into the sand so much sometimes that it brakes off. I use spring steel and when rusted I replace it.
