Hi Guys
I need some advice on fuses
I have just installed a switch panel with fuses to neaten the spaghetti mess that I had, but i cannot source the fuses recommended for the various electronics (glass vial fuses)
Lowrance LMS350A recommends a 3 Amp fuse
Uniden MC1010 recommends a 6 Amp fuse
Navstar 220 ? 29MHZ no instruction manual
Compass lighting Ritchie recommends 1 amp usage
Lights on the boat ?
The only fuses I can source are 5Amps, 10 Amps that were used previously.
My question is are there fuses out there like 3 amps or do i just go for broke and put 5 amp fuses in like before.
What amps for lighting ie port starboard and central white light
Your thoughts would be appreciated
