[font=Arial]Carbon prepreg is expensive stuff. [co
bandit1
Carbon prepreg is expensive stuff. A 50m roll can cost thousands of pound, and we consume kilometres of it each month. The resin, a modified epoxy system, does not cure at room temperature, but needs heat to make it solidify. This means the prepreg will not cure at room temperature and can be refrigerated to keep for very long periods.
Carbon fibre alone, is a black floss like material, very vulnerable to abrasion and damage. It is only by combining it with a resin  system that we get a composite that is useful as an engineering material. So when we talk loosely about carbon fibre fishing rods we normally mean carbon fibre and epoxy composite, but that is a bit of a mouthful!
Chemically and physically, carbon is an interesting substance that has the ability to bond one atom to another in several different stable ways by virtue of it's covalent bonding properties. Diamond is made of carbon and is one of the hardest substances known to man. Carbon fibre has the carbon in long chains to produce excellent tensile properties. By the way, the Americans and much of Asia calls carbon fibre graphite. Graphite is actually a totally different form of carbon with flat sheet like molecules which have lubricating properties. More recently carbon has been formed into new stable forms such as nano-tubes and buckyballs.
Prepregs differ in fibre type, orientation and properties, resin content, and weight per square metre. At any one time we have about ten materials in use. Most have fibre in only one direction, though some combine two fibres at different orientations. We do not make a rod with one fibre from tip to butt, but use different prepregs throughout the rod, often combining three or four in one rod. The reason for this is because different parts of a rod do different things. The tip for example requires fibres to stretch more as it bends into a curve.
[align=left]
[align=center]Table from Toray http://www.toray.com/[/align]
[/align]
Carbon Fibres come in a variety of types, and brands. IM6 and IM8 were heavily promoted at one time, but other major products are, M55, M40, M40J, M46J, T300, HR40, a long list. Each producer, and there are many, has its own brand of fibre that may be equivalent to a fibre from another maker. These fibre types vary in properties when they are tested on their own, putting them into a composite structure complicates everything and the strength and stiffness becom more dependent on the fibre orientation and resin  properties.
So what is fibre modulus and strength. Modulus, is in effect "stretchiness". It is different to strength but can easily be confused. When you make a composite using high modulus fibres, you make a stiff tube or rod. When you make a high strength tube, it may bend more, but it will bend further before failing. Think of an elastic band that stretches when you hang a weight from it. The amount of stretch is proportional to the weight. If you look at how much stretch you get for the added weight and use the cross sectional area of the rubber to convert this into a constant for all sized rubber bands, you have a measure of modulus. Carbon fibres stretch very little, that is why they are so useful, but the amount of stretch can measured and varies from a low modulus fibre to a high modulus fibre.
Strength is much more easy to understand. It is how much weight our rubber band or carbon fibre can support before it breaks. As a rule of thumb, with carbon fibres, as modulus increases, strength declines. That is why there is no one best fibre. That is why you cannot say a 50 ton rod is better than a 30 ton rod. And by the way, when a fly rod is branded as 50 ton, it will typically only contain a relatively small amount of this fibre, just as boron fishing rods only used to contain small quantities of boron.
Fishing rods across a range of applications need high strength, high modulus and intermediate fibres to perform well. No one fibre is superior. High modulus though often more expensive, is less preferable than a cheaper fibre in some applications. If you had to name one great all rounder fibre, it would be the T800/M30 family of intermediate fibres which are both extremely strong and have an increase in moudulus over standard high strength fibres.
So I assume that rather than clearing things up I have raised more questions than I have answered. This is why here at Harrisons we tend to be a bit vague about where we use different fibres and what they are. This is for two reasons. One, we believe we are ahead of the game, and we do not want to help our competitors. Two, it is almost meaningless to the angler because the picture is so often confused by the claims of the companies that outsource rod blanks and rods.
In summary therefore, I can say that there is no one best fibre. It makes no sense to use one fibre throughout a rod. When companies claim they use a certain fibre such as 50ton, they generally mean the rod contains some of that but not neccesarily througout. And finally, I recommend that you ignore the marketing blurb, pick up a rod and judge it on what you think and what you have heard. Is it well balanced, does it cast well, is it well made etc.
esign is the first step. That is the most secret bit here,  but one important ingredient is experience.  There are a small handful of really knowledgeable quality blank makers in the world. We are one of them, and it was hard work getting there! So sorry, not too much information is public domain here. I can tell you we sometimes start a design with a blank sheet of paper, but more often we take an existing blank, and play around with it. Unlike those companies sourcing their rods from the far east, we have total control. We can go through a cycle of design to prototype in two hours. The importers tell you it took two years to develop a new rod. Most of that was probably spent waiting for samples. We can develop a rod here in hours. But then we test it for months.
A design has to be translated into a pattern. Like a dress design. Three dimensional tube, starts out as two dimensional pattern. The patterns are cut by hand from the prepreg. A rod section may be made from one simple wedge shaped pattern, or more often a complex lay up of irregular shapes and different materials. The subtleties of design make the difference. The little changes in taper, stiffening, the balance of materials. Particularly critical is the joint area where a Harrison blank will have a smoother transition than many cheaper rods.
The other variable besides materials, is the mandrel, the tapered rod around which the tube is formed. We have a large stock of mandrels of various tapers and size. These are made to our specification in America. We have a large number of each type, as it is uneconomic to make rods one at a time, we have to work in batches.
from Harrisons Rods UK
bandit1
After doing alot of research om carbon and fibres , i can only come to one conclusion..some of us including myself have been duped.
we have no idea what we have been sold...and we have a right to know.
bastion
I come to a different conclusion, which is the same as the Author of that piece, ie that the process is too complicated to expect all anglers to understand so like he says in the article, it's probably better to forget about this technical stuff and go for the rod that casts/feels best to you in your hand regardless of the manner in which it was manufactured.  Use the graphite type to narrow down your search (ie you know you like 36T or whatever), and then try them from there.
Interesting in his piece though - he only briefly touches on the Resins used which is a major factor. Blank manufacturers spend a massive amount of time and money for RnD on which resins to combine with the carbon fibre to achieve a specific type of flex. More than likely the resins used are the difference between good and bad blank manufacturers, or more likely consistant and non consistant blank manufacturers.
bandit1
thank you. i agree.
but you will not believe the nonesense you here from tackle shops , in fact even suppliers.
the only one true anwser i got was from purglass , who explained excactly what you are saying, thats why i am purchasing 3 of the new slimline rods from craig this week.
but in a nutshell i concur.
put this on line so that some of the uninformed , like myself can make a better decision when purchasing a new rod
Bending Rod
Hi guys.
I have a question that might seem to you guys as 'huh'? But Im serious.. just learning as I go along.
(*shyly*) What is a purglass rod? I see the guys normally just refer to them in a numerical form, ie. 400/2 or something like that.
Which manufactures / models can i look out for? How are they different to HMG rods?
Your guidance/advise will be highly appreciated.
Cheers.
bandit1
bending rod
craig will be able to help you out...especialy on the purglass.
Enigma , can you help us out with this ..please
ask him about the new slimline range from purglass
Just as there are many variants of modulus and fibre strands there are many manufacturers of pre-pregs.
Then using the same pre-pregs one can by means of layering and rolling and oven baking process the same amount of material by one manufacturer can provide a crips and respnsive rod and the next can provide a slow bouncy rod with half the casting capacity.
As Bastion say's personal choice and affinity to the feel and action of the rod makes for what you want to go for.
Purglas is currently not HMG although they will add HMG to the stable at some stage as many end users are so totally caught up in the HMG desire that they just have to have a stiff as a broom, light as possible rod.
The closest one could probably get to describing the pre-pregs used by Purglas is that they use Glass and carbon pre-pregs that are probably best explained or compared to T24 and T30 as used in the market Vernacular in south Africa
Purglas Carbon rods are Carbon rods manufactured from their Pre-pregs and are not HMG (currently) I seriously doubt they will go full HMG but probably a blend of HMG and current pre-pregs.
The above piece makes one wonder how many of the rods sold here are 100% IM9 or T48 and not a blend of T24 and T48 etc, etc
As for the questions of why a Purglas, or any locally manufactured
1. The rods are designed and manufactured to meet the requirements of the unique way and target species we have in South Africa. Many if not all the mass imported products are copied from locally designed and manufactured rods
2. Because they rods are manufactured here by company's that have been around for many years (50 years +) and all rods they ever produced can be reproduced and if you have a multi piece rod they can replace the section that is broken even if it's a rod that was discontinued 10 years ago (they have the patterns of every rod they have ever built)
bandit1
::Swell said.
they say , the truth sets yu free. Well the truth has certainly made me a believer .
no  longer will i just jump on band wagon, i will make informed decisions , and if the supplier cant supply the truth i will not buy.
thank yu craig, thank yu sealine ..certainely the most informative site EVER.:SSS
