Flyfishing for Yellowfish
The Owner
Think we should organise a trip sometime:fishn. With regard to the strike indicator...the length of it should be equal to the depth you are fishing. In otherwords I usually look at the depth I am wading in to get an idea of the depth of the water I'm fishing and then adjust the indicator so the length between the indicator and top fly is equal to the depth I'm standing in. Also remeber that your indicator lifts your fly from the bottom (especially when their are no splitshots on the line). You ideally want your top fly to flow just over the rocks on the bottom. If your fishing 30cm deep water and uour indicator is 1.5m above your top fly you will miss a lot of strikes as yellows and suck/spit your fly without your indicator showing it. Once you start realising how all of this works your success rate improves greatly
Fishpaste
Your indicator measurement does make more sense than what I followed in the link...there it simply states to have it 1.5x the depth, but doesnt tell you to which fly... This is where I then made the indicator longer so that both my flies get down to the desired depth, for some reason I didnt even think of using splitshots.
The Owner
Never been to Sunnyside farm, are there many rapids and how is the fishing pressure ito fly anglers? Fishpaste, I reckon the fly you used must have been a heavy GRHE to get down in the current without splitshots. I figured out the length of the indicator to fly the hard way...through struggling with it for an entire day until I clicked how it influences the fly and what length picked up the most strikes. Much better to share this knowledge than struggle on your own::S
Fishpaste
Personally, it is the only place I have been to on the Vaal, flyfishing pressure there is almost none, but there are not massive rapids really in my opinion, but none the less really nice. Biggest we have caught was a 2.3kg SM on a previous trip, but on white dough papgooi style...was mid May somewhere and the weather was really cold and we struggled... there are a heck of a lot of snags too above the weir... for the whole weekend we lost the only carp that took the bait and landed maybe 4 yellows in total...
