Fishing line help needed
Hennas89
I am fishing conventional and what I have read everywhere is that the norm is about 5lb fishing line for your mainline with a leader.
Now I have the following questions how many pounds must the leader line be more or less and what should the length of the leader line be?
What line strength must your hook lines be?
Any assistance would be appreciated
tadeo
Leader must be strong enough to cast what you have at the end of your line or to take the abrasion of the bottom of the pond. Two or three turns around your reel.
If you are going to use 5lb line in an area that is grass/weed/debris free than fine. If you think you might get snagged ,think twice about it. Not nice getting the place full of broken line and hooks.
::tight:
Hennas89
Thank you will keep that in mind. One stupid question when you say 2 or 3 turns around the reel you mean when the reel is not on the rod or do you mean when reel is on the rod and the "strop" is on and ready to be cast the leader must be 2 or 3 turns around the reel. Apologies for the dumb question
tadeo
Hi. Van sinker/baitcage ..deur die oogies ..tot op die katrol. Dit sal dan dieselfde efek he asof jy bv. 20lp lyn gaan gooi en dan kan jy dit maar wetter.
Hoop jy kom reg
